Graylog can't read OpenSearch JSON to connect
Hi, I’m having an issue when trying to connect my OpenSearch server to my Graylog server. I’m able to start and run OpenSearch seemingly without issues, however when I try to start Graylog I get these error messages:
2024-06-20T14:19:07.380Z INFO [VersionProbe] OpenSearch/Elasticsearch is not available. Retry #27
2024-06-20T14:19:12.385Z ERROR [VersionProbe] Unable to retrieve version from OpenSearch/Elasticsearch node <OpenSearch’s ip address>: unknown error - an exception occurred while deserializing error response: com.fasterxml.jackson.core.JsonParseException: Unexpected character (‘<’ (code 60)): expected a valid value (JSON String, Number, Array, Object or token ‘null’, ‘true’ or ‘false’)
at [Source: REDACTED (StreamReadFeature.INCLUDE_SOURCE_IN_LOCATION disabled); line: 1, column: 1]
However, when I run a curl command to the address of my OpenSearch server I get what seems to be a valid JSON document:
“name” : “main-node”,
“cluster_name” : “graylog”,
“cluster_uuid” : “Sr-4UlL6Tu6W7mqu06RMPQ”,
“version” : {
“distribution” : “opensearch”,
“number” : “2.12.0”,
“build_type” : “deb”,
“build_hash” : “2c355ce1a427e4a528778d4054436b5c4b756221”,
“build_date” : “2024-02-20T02:18:31.541484890Z”,
“build_snapshot” : false,
“lucene_version” : “9.9.2”,
“minimum_wire_compatibility_version” : “7.10.0”,
“minimum_index_compatibility_version” : “7.0.0”
“tagline” : “The OpenSearch Project: https://opensearch.org/
I’m running OpenSearch on Ubuntu Server 24.04, and running Graylog and MongoDB on a separate server, also on Ubuntu Server 24.04.
Edit: I forgot to mention I’m using version 6.0 of Graylog, sorry.
Guessing elasticsearch_hosts is not set in your graylog.conf.
And yes, the name is confusing :confused:
No I did, here is what server.conf looks like:
GRAYLOG_SERVER_JAVA_OPTS=“-Xms2g -Xmx4g -XX:NewRatio=1 -server”
is_leader = true
password_secret =my password secret
root_password_sha2 =my root password
http_bind_address = “ip of this server”:9000
elasticsearch_hosts = http://“ip of OpenSearch server”:9200
disabled_retention_strategies = none,close
allow_highlighting = false
field_value_suggestion_mode = on
output_batch_size = 500
output_flush_interval = 1
ring_size = 65536
inputbuffer_ring_size = 65536
mongodb_uri = mongodb://localhost:27017/graylog
http_proxy_uri =address of proxy server
Nevermind I am very dumb, I set a proxy uri but didn’t exclude my OpenSearch server… Sorry to have wasted your time
