I have rather peculiar problem. I need to get Mikrotik remote logs into Graylog server. The Google is full of topics that it can’t be done. I disagree! At first I dig out that the RB450G seires router is sending UDP packet payload like this:
Do I really have to degrade Graylog to version 3.1.3? Still the fact is that tcpdump is showing that the logs are coming to Graylog server and the point must be in log parsing or in server.
Issue description is not clear actually and I see jan also confused.
What exactly you can’t realize? Receive logs? Parse logs? How exactly you tried to verify it(timestamp related issues are very common)
This part looks unclear
Where exactly you route logs, can you show Mikrotik configuration? Where did you check tcpdump? On graylog side? Can you share pcap file?
I’m not unsure what’s coming. As you can see my first post the tcpdump is showing what’s coming into the port where input is listening. I changed my production IP addresses to 0.0.0.0 and removed the message content as well. Sorry zoulja for confusion. Thought that it’s obvious to figure out why there are zeros. Sorry
“What exactly you can’t realize? Receive logs? Parse logs? How exactly you tried to verify it(timestamp related issues are very common)”
I can’t get my production Graylog to read (see) incoming messages from HAP series Mikrotik routers. Verified the input with tcpdump. Please note that there is a difference in UDP packet. But why the Graylog 3.1.3 is reading all incoming packets and 3.2.2 is not?
I was hoping to get some ideas what to check or change. The router configuration is OK and the logs are coming like you can see from my first post. There is something with server or Graylog configuration. My production server have 2 NIC’s and 2 different IP addresses. This is the only difference between the home lab and production server. And the Graylog version to of course.
Tired the RAW input. The result was same. Graylog can read RB450G but not HAP. At first my idea was that the line break in HAP log „?.dp{{line break}}…r,“ (note it from my first post) is the case, but I’m confused because in my home lab it was working. Is it the Graylog version or the 2 NIC’s?
The timestamp is not the issue, I think because I have checked the „allow_override_date: true“? And also just checked that the timestamps are correct. Thanks zoulja for the tip!
Added a snippet from wireshark. Hope it helps a littele…
So I have downgraded the production Graylog server to version 3.1.4 (my home lab is v. 3.1.3) and everything is working fine. My conclusion is that for now I can’t update Graylog server above version 3.1.x.
I hope that this bug will be fixed soon, because Graylog is cool and powerfull tool!
if no bug report is given - no bug can be looked at and might get a fix.
I guess that the send syslog messages are not following the RFC or similar. If you use a RAW input you could have checked that on Graylog … what the actually package contains.
