Graylog can not show event Definitions on web
i just run command " sudo -u graylog echo ‘db.scheduler_triggers.remove({})’ | mongo graylog " to remove scheduler_triggers on mongodb , but afer I run command , on graylog web i can not create new event definitions, how can i do to fix that?
Logs: ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
java.lang.NullPointerException: null
  • OS Information: ubuntu 18.04
  • Package Version: Graylog 4.2.6+0210617
Hello && Welcome
Oh Man… probably not good.
Perhaps this would help
