GrayLog boolean stream rule doesn't seem to filter correctly
It seems like I could be missing something big, but couldn’t anybody tell me why this doesn’t work??
In the example you show, it is not clear if is_candle has been broken out to a separate field. You are showing it mixed in the $message.message field. Are you breaking it out to its own unique field before you are applying the stream rule?
Thanks! That’s perfect. Got me headed in the correct direction.
