btown1
(Brian Town)
August 15, 2020, 12:22am
1
My setup is a reverse proxy on our boundary that is pointing into our internal network and my graylog server.
I set up my graylog server running apache with following config to reverse proxy it locally, which works just fine with following setup:
<VirtualHost :80>
ServerName graylog.internal.domain
RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteRule ^/?(. ) https://%{SERVER_NAME}/$1 [R,L]
<VirtualHost *:443>
ProxyRequests On
SSLEngine on
SSLCertificateFile /etc/pki/tls/certs/graylog.pem
SSLCertificateKeyFile /etc/httpd/graylog.key
SSLCACertificateFile /etc/pki/tls/certs/ca.pem
<Proxy *>
Order deny,allow
Allow from all
RequestHeader set X-Graylog-Server-URL “https ://graylog.internal.domain/”
ProxyPass http ://127.0.0.1:9000/
ProxyPassReverse http ://127.0.0.1:9000/
My outside proxy has the following config pointing at it:
<Location /graylog>
ProxyPass https: //graylog.internal.domain/
ProxyPassReverse https ://graylog.internal.domain/
When I click the link on the outside proxy all I get is just a static white page instead of the graylog login. Is there a subpath or something in graylog server.conf I should be using? I modified the trusted_proxies setting but that didn’t seem to work.
btown1
(Brian Town)
August 15, 2020, 12:42am
2
If I turn off httpd on the graylog server itself and set it up to bind to $IP:9000 and set http_external_uri to the https://graylog.internal.domain:9000/ address it still works (with cert config setup in server.conf as well)
But on the outside proxy, pointing it to ProxyPass https://graylog.internal.domain:9000/ fails with:
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later
btown1
(Brian Town)
August 15, 2020, 8:33pm
3
Above when I get a blank screen connecting to Graylog through the proxy.
btown1
(Brian Town)
August 17, 2020, 6:09pm
5
I did see this in the config, but not sure how to translate it to Apache
server
listen 80 default_server;
listen [::]:80 default_server ipv6only=on;
server_name applications.example.org ;
location /graylog/
proxy_set_header X-Graylog-Server-URL http://$server_name/graylog/;
rewrite ^/graylog/(.*)$ /$1 break;
proxy_pass http://127.0.0.1:9000;
btown1
(Brian Town)
August 18, 2020, 6:12pm
6
Got it to work so for future people who google search this here is what I had to set up!
Graylog server.conf only has http_bind set to 0.0.0.0:9000
Nginx config on graylog server:
server
listen 443 ssl http2;
server_name external_proxy_hostname ;
ssl_certificate /etc/pki/tls/certs/graylog.pem;
ssl_certificate_key /etc/httpd/graylog.key;
location /graylog/
proxy_set_header X-Graylog-Server-URL https://$server_name/graylog/;
proxy_pass http://127.0.0.1:9000 ;
Make note that the server name is the external proxy, not the hostname of the graylog server
Apache config for external proxy:
<Location /graylog>
ProxyPass https://$GRAYLOGIP/graylog/
ProxyPassReverse https://$GRAYLOGIP/graylog/
