Graylog API for frontend
I am able to run graylog server and also able to read logs from other servers from sidecar/filebeat.
I have a frontend application which need to send log to graylog server or elastic search. Any recommended way to handle this. Do we have any REST API which i can call in my frontend application to send log. i am quite new to graylog .
  • OS Information:
  • Package Version: graylog 4.1
Hello && Welcome
I would really like to help but your question is kind of open-ended. With the lack of information about you environment it hard to give a direct answer to your question. For example:
With a better understanding how you set up your graylog server or the way you ingesting logs would help. I could simple say use Graylog Sidecar.
https://docs.graylog.org/docs/sidecar
Perhaps that will help.
Thanks for response . I think i got the solution. Due to my application is frontend one , which did not generate log files. So i can use below GELF approach to send logs directly to graylog as a Service or ajax call .
curl -X POST -H ‘Content-Type: application/json’ -d ‘{ “version”: “1.1”, “host”: “example.org”, “short_message”: “A short message”, “level”: 5, “_some_info”: “foo” }’ ‘http://graylog.example.com:12201/gelf’
Oh nice, and thanks for post your resolution. Please mark it a solved so it can help others for future searches.
Good Job :+1:
