Graylog and Sigma rules
Hi!
I collect raw logs from sysmon to the stream “sysmon-logs”
like here
https://www.graylog.org/post/back-to-basics-enhance-windows-security-with-sysmon-and-graylog
Now I found the project Sigma (Generic Signature Format for SIEM Systems)
Graylog has support (convert generic Sigma rules into Graylog search queries)
What is the best way to load sigma rules for sysmon into the Graylog?
Create for example new stream “sigma-alert”.
Sigma rules generate a search query to be used in Graylog.
You would just use the created searches on your already given data and might save them as ‘saved searches’
