Graylog and Gmail
I am trying to integrate gmail into graylog. I already integrated google workspace and it worked fine. Now that I’m integrating gmail, I keep getting this error:
[BigQueryService] Exception Occurred while deleting tables older than checkpoint timeNot found: Dataset gray-111333:gmail_dataset (real data changed).
[GmailClient] Exception Occurred while listing Available Tables in BigQuery Not found: Dataset gray-111333:gmail_dataset
No logs are reported.
I’m following these instructions:
https://docs.graylog.org/docs/google-input
And using the same project I used for the Google Workspace integration. The workspace works fine.
It’s not clear what
  • OS Information:
    Debian 10
  • Package Version:
    Graylog 4.2.4+b643d2b
I’ve tried changing the configuration and adding only the numbers for the ID, using the service account number, using my full account number, none of these work.
Help me understand if there is something missing in the integration, or what the error message might mean.
Are you using the same input for your workspace as your Gmail?
I’m not to familiar with Graylog Gmail Input configurations, It seams the dataset gray-111333 cant be found. Have you check elasticsearch?
Example:
curl -XGET http://localhost:9200/_cat/shards
Have you tried to manually rotate your Index?
Hey,
No, it is a separate input in graylog, same project in Google Cloud.
I’m a ittle confused with this message. That dataset the project id in google cloud console. I’m not sure were elasticsearch would come in since it won’t even call it in the API.
curl -XGET http://localhost:9200/_cat/shards`
I’m new to graylog, so I tired this but I’m not sure what I’m supposed here.
I don’t think this would help since it seems like the problem is with the API: it seems like the project can’t be found on the Google side.
Sorry for the delay I was on vacation.
It seams some where you used to have a data set called gray-111333 Now elasticsearch cant find it.
For example my data set looks like this, it called graylog_1461
Here is the rest of them.
I was suggesting to rotate you index manually to see it that could clear it up. If you no longer have that dataset then this would not matter.
Using this command.
I was hoping you could see your dataset, if it exists at all. Here is an example of mine.
I’m just referring to the error shown above.
EDIT: Quick question, are these logs from your Graylog server side or your Google side?
