Hi everybody,
I have podman containers, and want to connect graylog to ferretdb instead of mongodb, but i get errors while trying to get it connected:
Blockquote
2025-04-01T10:14:08.918Z WARN clientconn/conn.go:624 Response message:
FlagBits:[],
Checksum: int64(0),
Sections: [
Kind: 0,
Document: {
ok: 0.0,
errmsg:no such command: '{ ping: 1 }',
code: 59,
codeName:CommandNotFound,
} {“name”:“listener”}
Or an error like this:
ERROR: Unable to connect to MongoDB. Is it running and the configuration correct?
Details: Command failed with error 115 (CommandNotSupported): ‘Error in specification { “key” : { “title” : 1 }, “name” : “title_1”, “collation” : { “locale” : “en” } } :: caused by :: createIndex.collation is not implemented yet’ on server ferretdb:27017. The full response is {“ok”: 0.0, “errmsg”: “Error in specification { "key" : { "title" : 1 }, "name" : "title_1", "collation" : { "locale" : "en" } } :: caused by :: createIndex.collation is not implemented yet”, “code”: 115, “codeName”: “CommandNotSupported”}
Terminating.
It then simply terminates.
OS Information:
Debian 12, 6.1.0-23-amd64 -
Package Version:
podman version 4.3.1
ferretdb:2.0.0
postgres-documentdb:17-0.102.0-ferretdb-2.0.0
graylog/graylog:6.0
graylog/graylog-datanode:6.1.4 -
- Since Ping is not supported by ferretdb, i tried to avoid that in compose, not really working.
- Try to get it run with mongodb until first config is done and then switch to ferretdb → different errors, also does not work correctly.
Did anyone also tried to get graylog run with ferretdb instead of mongodb?
Best regards
