Graylog Alert and dashboard setup
How to show number of triggered alert or others information from alert notifications on dashboard graylog 5.0.
Hey @fluky
Chances are, if you created a alert and/or notification then that steam/s or those filed/s to create it can be used on a widget the applied to a dashboards, just an idea
All events and alerts generate a message in the ‘All events’ stream:
you can use this to create an aggregation to show different metrics, like total count.
hope that helps.
