Graylog 7/ Mikrotik logs are not coming in
Hi! Installed graylog 7 according to the official documentation with the standard configuration. I wanted to use it to collect logs from Mikrotik. Created Input, but no messages appear in graylog. I tried different ports and protocols, all to no avail. Through Tcpdump, packets from mikrotik arrive at the graylog server, but graylog shows nothing. The firewall is disabled. I don’t understand what the problem could be. Maybe graylog, when creating Input, is not listening to the specified port?
1. Describe your incident: Logs are not appearing in Graylog
  • OS Information: Debian 12, VMware Workstation
  • Package Version: Graylog 7.0.13-1, Datanode 7.0.13-1, Mongodb 7.0.43
  • server.log
    2026-10-07T09:27:46.821+03:00 INFO [NetworkListener] Started listener bound to [192.168.2.141:9000]
    2026-10-07T09:27:46.822+03:00 INFO [HttpServer] [HttpServer] Started.
    2026-10-07T09:27:46.823+03:00 INFO [JerseyService] Started REST API at <192.168.2.141:9000>
    2026-10-07T09:27:46.823+03:00 INFO [ServiceManagerListener] Services are healthy
    2026-10-07T09:27:46.824+03:00 INFO [ServerBootstrap] Services started, startup times in ms: {UserSessionTerminationService [RUNNING]=0, GracefulShutdownService [RUNNING]=0, InputSetupService [RUNNING]=1, NotificationSystemEventPublisher [RUNNING]=1, PrometheusExporter [RUNNING]=1, MigrationShutdownService [RUNNING]=1, EtagService [RUNNING]=2, BufferSynchronizerService [RUNNING]=4, OutputSetupService [RUNNING]=6, LocalKafkaMessageQueueReader [RUNNING]=7, LocalKafkaMessageQueueWriter [RUNNING]=8, FailureHandlingService [RUNNING]=8, UrlAllowlistService [RUNNING]=8, JobSchedulerService [RUNNING]=12, StreamCacheService [RUNNING]=19, GeoIpDbFileChangeMonitorService [RUNNING]=21, LocalKafkaJournal [RUNNING]=39, ConfigureCertRenewalJobOnStartupService [RUNNING]=61, LookupTableService [RUNNING]=65, MongoDBProcessingStatusRecorderService [RUNNING]=95, PeriodicalsService [RUNNING]=175, JerseyService [RUNNING]=1750}
    2026-10-07T09:27:46.833+03:00 INFO [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
    2026-10-07T09:27:46.890+03:00 INFO [ServerBootstrap] Graylog server up and running.
    2026-10-07T09:52:08.871+03:00 INFO [SessionCreator] Invalid credentials in session create request. Actor: “urn:graylog:user:admin”
    2026-10-07T09:53:11.445+03:00 INFO [SystemProcessingResource] Paused message processing - triggered by REST call.
    2026-10-07T09:53:15.532+03:00 INFO [SystemProcessingResource] Resumed message processing - triggered by REST call.
    2026-10-07T09:53:49.923+03:00 INFO [InputStateListener] Input [Syslog UDP/Syslog UDP input/6ac4e37bc7d3d85e334a5ee6] is now STOPPING
    2026-10-07T09:53:49.925+03:00 INFO [InputStateListener] Input [Syslog UDP/Syslog UDP input/6ac4e37bc7d3d85e334a5ee6] is now STOPPED
    2026-10-07T09:53:49.926+03:00 INFO [InputStateListener] Input [Syslog UDP/Syslog UDP input/6ac4e37bc7d3d85e334a5ee6] is now TERMINATED
    2026-10-07T09:55:24.072+03:00 INFO [InputStateListener] Input [Syslog UDP/Syslog UDP input/6ac4e37bc7d3d85e334a5ee6] is now STOPPING
    2026-10-07T09:55:24.077+03:00 INFO [InputStateListener] Input [Syslog UDP/Syslog UDP input/6ac4e37bc7d3d85e334a5ee6] is now STOPPED
    2026-10-07T09:55:24.081+03:00 INFO [InputStateListener] Input [Syslog UDP/Syslog UDP input/6ac4e37bc7d3d85e334a5ee6] is now TERMINATED
    2026-10-07T09:55:37.508+03:00 INFO [InputStateListener] Input [Syslog UDP/Syslog UDP input/6ac4e37bc7d3d85e334a5ee6] is now STOPPING
    2026-10-07T09:55:37.509+03:00 INFO [InputStateListener] Input [Syslog UDP/Syslog UDP input/6ac4e37bc7d3d85e334a5ee6] is now TERMINATED
    2026-10-07T09:55:37.510+03:00 INFO [InputStateListener] Input [Syslog UDP/Syslog UDP input/6ac4e37bc7d3d85e334a5ee6] is now STOPPED
Your input is not running yet, it is in the “set-up input” state. You need to click that yellow button and follow the wizard.
Thank you very much for the help. I had overlooked that point; that was the problem.
