Graylog 6.1.7 - Output to file
Hi all,
in the past (till graylog 4.1.5) I successfully used the following plugin:
GitHub - rswestmoreland/graylog-delimited-file-output-plugin: An output plugin for Graylog2, providing the ability to export messages to disk as CSV, TSV, space or pipe delimited files.
This allowed me to export logs directly to file (txt, json, etc.) directly using Outputs in cluster.
Now this plugin doesn’t work anymore on the new version.
Is there something similar or do you know any other way to accomplish this?
Thanks,
Antonio.
Hi all,
any tips?
Thanks,
Antonio.
Hey @tonystra,
Graylog lets you export a search as CSV from the UI.
You could output as syslog to rsyslog listening on a port and have rsyslog write that to a file, not quite as simple though.
after some research, we landed on this fork: GitHub - 5bentz/graylog-delimited-file-output-plugin: An output plugin for Graylog2, providing the ability to export messages to disk as CSV, TSV, space or pipe delimited files
Thanks,
Antonio.
