Graylog 5.2 Question: Active Directory & TLS Options
Not an incident, just a question of how these two options work. I do not see any information regarding these authentication options in Graylog’s Docs. Nor can I seem to find any details in the support forum.
Running on Graylog 5.2 for Active Directory Authentication.
The option for TLS, does anyone know if this is forced TLS? Or does it just try TLS and if it fails it defaults to no encryption.
Also what does the checkbox for Verify Certificates do?
  • OS Information:
    Ubuntu 22.04 LTS
  • Package Version:
    5.2
Thank you.
