Graylog 3.0 Sidecar
Hello All,
I’m testing Graylog 3.0 in my environment, everything seems to work so far, no problems yet. I decided to use Graylog sidecar for the first time and it was easy to configure on the remote client. I was able to see my remote host appear as shown below:
001-version
Under “Manage Configuration” worked good also, no problem:
002-managment
My question is about “Sidecars Overview” its blank. Not sure what I did wrong. I am receiving message from my remote client. I was able to configure NXLog from Graylogs GUI without any problems.
Following is what I see. Any help would be appreciated…
Sidecars Overview:
Collector Configuration:
Collector Administrator page is also blank:
Environment:
Graylog-Server as follow;
CentOS7 Virtual machine on Windows Hyper-V
Graylog 3.0.0-rc.1+f41986c
Elasticsearch-6.6.0-1.noarch
Mongodb-org-4.0.5-1.el7.x86_64
Remote machine sending log to Graylog server as follow;
NXLog installed
Install the following;
rpm -i https://github.com/Graylog2/collector-sidecar/releases/download/0.1.6/collector-sidecar-0.1.6-1.x86_64.rpm
graylog-collector-sidecar -service install
two notes on that:
  • you need to use sidcar later than your selected version (0.1.7 minimal)
  • why did you use the legacy version with 3.0? This will be abonned and removed in the near future. Go with the new!
@jan
Thanks for the reply, Installing the New,and thank you for the tip on the version.
Is there a way to disable the legacy system? I do not want old Collector Sidecars to register themselves again, but I cannot seem to find anything in the settings to turn off the legacy sidecar connections.
