Hello
Graylog constantly gives the following warning.
What would be the reason ?
error:
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_121]
2017-03-06T13:35:39.197+03:00 INFO [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2017-03-06T13:35:39.705+03:00 WARN [V20161130141500_DefaultStreamRecalcIndexRanges] Interrupted or timed out
2017-03-06T13:34:52.609+03:00 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
org.elasticsearch.discovery.MasterNotDiscoveredException: null
Sockets:
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:27017 0.0.0.0:* LISTEN 1248/mongod
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 1159/sshd
tcp6 0 0 192.168.1.24:9000 :::* LISTEN 2092/java
tcp6 0 0 192.168.1.24:9200 :::* LISTEN 1935/java
tcp6 0 0 192.168.1.24:9300 :::* LISTEN 1935/java
tcp6 0 0 :::22 :::* LISTEN 1159/sshd
tcp6 0 0 127.0.0.1:9350 :::* LISTEN 2092/java
tcp6 0 0 ::1:9350 :::* LISTEN 2092/java
udp6 0 0 192.168.1.24:5142 :::* 2092/java
Elasticsearch.yml:
cluster.name: graylog
network.host: 192.168.1.24
discovery.zen.ping.multicast.enabled: false
script.inline: false
script.indexed: false
script.file: false
# curl -XGET 'http://192.168.x.x:9200/_cluster/health?pretty=true'
"cluster_name" : "graylog",
"status" : "green",
"timed_out" : false,
"number_of_nodes" : 1,
"number_of_data_nodes" : 1,
"active_primary_shards" : 1,
"active_shards" : 1,
"relocating_shards" : 0,
"initializing_shards" : 0,
"unassigned_shards" : 0,
"active_shards_percent_as_number" : 100.0
Thanks.
