Graylo2 Docker: failed to register layer
Hi guys,
I am trying to install graylog as a docker container but i am getting the following error:
[root@adc01dvy tmp]# docker pull graylog2/server
Using default tag: latest
latest: Pulling from graylog2/server
fdd5d7827f33: Already exists
a3ed95caeb02: Already exists
0f35d0fe50cc: Already exists
44091295bce9: Already exists
a7df6b0e1928: Already exists
e3f5c6e4eb7c: Already exists
078144e1612b: Already exists
ff7dd9deb980: Already exists
2dde0d1f056f: Extracting [==================================================>] 818.8 kB/818.8 kB
3f940663e27c: Download complete
c7a355b4b9ca: Download complete
035e82ace0dc: Download complete
636665a0eab2: Download complete
0daca34a1dac: Download complete
failed to register layer: stat /var/lib/docker/btrfs/subvolumes/0bbe986ffde3a010b40c1473cc85c36ed6a1990c7297f6b59807a85f51bd19dc: no such file or directory
Does anyone knows what might could be the root of the problem? How can i fix it?
Thank you all
[root@adc01dvy tmp]# docker version
Client:
 Version:      1.12.1
 API version:  1.24
 Go version:   go1.6.3
 Git commit:   23cf638
 Built:
 OS/Arch:      linux/amd64
Server:
 Version:      1.12.1
 API version:  1.24
 Go version:   go1.6.3
 Git commit:   23cf638
 Built:
I’m unable to reproduce this issue with the graylog2/server image:
$ docker pull graylog2/server:latest
2dde0d1f056f: Pull complete
3f940663e27c: Pull complete
c7a355b4b9ca: Pull complete
035e82ace0dc: Pull complete
636665a0eab2: Pull complete
0daca34a1dac: Pull complete
Digest: sha256:ac305af4528cb9e6c640d997bb1d363b3cbcea88883741852a71700705cd46b2
Status: Downloaded newer image for graylog2/server:latest
$ docker version
Client:
 Version:      17.06.0-ce
 API version:  1.30
 Go version:   go1.8.3
 Git commit:   02c1d87
 Built:        Fri Jun 23 21:31:53 2017
 OS/Arch:      darwin/amd64
Server:
 Version:      17.06.0-ce
 API version:  1.30 (minimum version 1.12)
 Go version:   go1.8.3
 Git commit:   02c1d87
 Built:        Fri Jun 23 21:51:55 2017
 Experimental: true
FWIW, try using the graylog/graylog Docker image instead.
Thank you for the tip. This worked. What are the diferences from the graylog2/server image to the graylog/graylog?
The graylog/graylog image is an automated build on Docker Hub and will eventually replace graylog2/server which is built on our own build infrastructure and then uploaded to Docker Hub.
Other than that they are pretty much identical.
