For HTTP request logs I have the HTTP status and I’d love to create a graph that represents the sum of successful requests over the total requests to give an uptime percentage. I can certainly create a bar graph that gives me counts for each status, but I’d love to output a % (either as a graph visualization, or even as a single number). It’s unclear to me how I might create an aggregation that does this math. Is it possible?
Hello && Welcome
I’m assuming your looking for something like this?
By using the aggregation widget, you can configure it like this.
Just a side note this is Graylog 4.0+, ES 7.10, and MongoDb 4.4.
Dont know if you have seen this.
https://docs.graylog.org/en/4.0/pages/searching/widgets.html
Hope that helps
EDIT:
I havent tried that type of configuration out, and I’m not sure Graylog can do those types of calulation on widget. I do know Zabbix can.
Ah, this makes sense! Since I probably can’t do the math in the aggregation to sum the 2XX, 3XX, 4XX requests I could do that in the pipeline and create a field which is “good/bad” on each request log and then get a % of good requests value out of this visualization that could be used as an uptime measurement.
Maybe this might help
https://docs.graylog.org/en/4.0/pages/pipelines/functions.html
You might be able to use some of these function here. Just an idea
