Getting correct timezone for timestamp
Hi all,
I’m trying to pull timestamp from messages instead of using filebeat timestamp. Its mostly working ok, but I have issues with Timezones.
Timezone of my Graylog Server and User is set to Pacific/Auckland. Timestamps in my streams are currently showing as: 2020-05-18 14:31:01 +12:00
I have some logs shipped from Australia ( Melbourne ), example message:
[DEBUG] 2020-05-18 12:32:37.577 User logged in: false
I’ve setup an extractor on my Beats Input for message field. I’ve used TIMESTAMP_ISO8601 GROK Pattern.
That works nicely, for the message above I get field TIMESTAMP_ISO8601: 2020-05-18 12:32:37.577
Then I’ve setup a new pipeline rule to create a new_timestamp date field.
rule "Change AU timestamp"
    has_field("TIMESTAMP_ISO8601")
    let new_date = parse_date(to_string($message.TIMESTAMP_ISO8601), "yyyy-MM-dd HH:mm:ss.SSS");
    set_field("new_timestamp", new_date);
After this rule is applied, field new_timestamp is created with value: 2020-05-19 00:32:37 +12:00
It seems like it adds +12 hours to the TIMESTAMP_ISO8601 field which already contains time Australian time (+10.00).
To resolve the problem I would probably need to add timezone information to my pipeline rule.
Here are the options I’ve tried without success:
let new_date = parse_date(to_string($message.TIMESTAMP_ISO8601), "yyyy-MM-dd HH:mm:ss.SSS", "en-AU", "AEST");
let new_date = parse_date(to_string($message.TIMESTAMP_ISO8601), "yyyy-MM-dd HH:mm:ss.SSS", "Australia/Melbourne");
I’m hoping to get new_timestamp filed to be 2020-05-18 14:32:37 +12.00 or 2020-05-18 12:32:37 +10.00
Then I could use it to replace original timestamp field.
Any help or pointers would be much appreciated.
I don’t know if graylog render correct timezone for other field than timestamp. Try to change it from new_timestamp to timestamp and try…
Thanks shoothub.
I think you can set timezones on other fields as well if you use parse_date function.
I’ve managed to resolve the issue with following format:
        value: to_string($message.TIMESTAMP_ISO8601),
        pattern: "yyyy-MM-dd HH:mm:ss.SSS",
        timezone: "Australia/Melbourne");
    set_field("timestamp", new_date);
