Gelf kafka input load balancing
I have Graylog cluster with 3 nodes. I have set input using GELF kafka and I send all my logs to kafka.
I send about 100 thousand logs to test my set up. I can see only one of the node (Node 1) tries to process all the 100 thousand logs while the other 2 nodes are not doing any processing. If I stop Graylog server on Node 1 and then send 100k logs, then Node 2 processes it while Node 3 is not processing. So i can see that all 3 nodes are able to read from the kafka topic but only 1 node processes the logs. How can I can balance the load between all 3 Graylog nodes?
https://github.com/Graylog2/graylog2-server/issues/3730
Tried creating a topic with 4 partitions. Still not working.
Solved issue by increasing the partitions adding the following property in server.properties file for kafka config.
num.partitions=4
If topics were created before adding this configuration, then add additional partitions manually using the kafka replication tools
bin/kafka-topics --alter --zookeeper localhost:2181 --topic topicname --partitions 6
Note: the number of partitions should be number of graylog server nodes multiply by 2.
https://cwiki.apache.org/confluence/display/KAFKA/Replication+tools
Restart the producer (source sending the messages to kafka) just to be sure.
as reference:
https://github.com/Graylog2/graylog2-server/issues/3730#issuecomment-306836611
