Function to divide a number by X
I have a field in bytes format and I need to displayed it in a dashboard in megabytes format.
After reading in existing posts, the only available way seems to be the use of a pipeline, by making the conversion in a function and adding an new field.
But I did not notice any mathematical function to allow division, ideally integer division…
I really want to avoid writing a plugin for a such basic stuff :frowning:
Do you know any existing add-on where can I find this kind of functions?
Any other solution for my problem is welcome :slight_smile:
Thanks in advance
This functionality has been implemented as arithmetic operators, e. g. / for division.
Thanks for your quick answer.
It will be nice if you could improve this part of the documentation:
http://docs.graylog.org/en/2.4/pages/pipelines/rules.html
Feels free to create a feature request (or even a pull request) in the documentation repository:
Just Done! Thanks again
