Feature : Import grok pattern with duplicate management
We works with differents graylog clusters. In differents cases, we export the grok pattern base and we import in the other cluster.
By default, Graylog doesn’t manage the duplicate grok pattern case and we delete the duplicate manually.
Is there any plan to manage this case? If no, is it possible to add it to feature ideas?
Please create a bug report at Issues · Graylog2/graylog2-server · GitHub.
OK @jochen
This topic can be closed
For reference:
https://github.com/Graylog2/graylog2-server/pull/4888
