Failed to send logs to my graylog in production
Hey all,
I set up a graylog in production mode. there are three graylog servers and two nginx loadbalancing server include keepalived in the same both server. after configuration I can not send the device log into my graylog
could you help me please?
What Graylog Version do you have? What kind of input did you configure? What kind of logs are you trying to send? Please be more specific.
I’m using version 2.4.6 of graylog, version 5.2.0 of ES. I configured inputs in udp (see capture)
I want to send log via my debian rsyslog. When I check in the logs of two server loadbalancing & failover here is what I am told
this my Nginx LB config
user nginx;
worker_processes 1;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                  '$status $body_bytes_sent "$http_referer" '
                  '"$http_user_agent" "$http_x_forwarded_for"';
access_log  /var/log/nginx/access.log  main;
sendfile        on;
#tcp_nopush     on;
keepalive_timeout  65;
#gzip  on;
include /etc/nginx/conf.d/*.conf;
upstream graylogwebcluster {
    ip_hash;
server 192.168.153.101:443 fail_timeout=10s max_fails=3;
    server 192.168.153.102:443 fail_timeout=10s max_fails=3;
    server 192.168.153.103:443 fail_timeout=10s max_fails=3;
server {
listen 80;
rewrite ^ https://192.168.153.90$request_uri? permanent;
#root /usr/share/nginx/html;
server
listen 443 ssl;
ssl on;
ssl_certificate /etc/ssl/certs/failover-lb2.lan.crt;
ssl_certificate_key /etc/ssl/private/failover-lb2.lan.key;
ssl_session_timeout 5m;
ssl_ciphers EECDH+CHACHA20:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
ssl_protocols TLSv1.2 TLSv1.1 TLSv1;
ssl_prefer_server_ciphers on;
ssl_verify_client off;
server {
listen 80 default_server;
    location / {
   	proxy_set_header X-Graylog-Server-URL https://graylogwebcluster/api;
    proxy_pass https://graylogwebcluster ;
#rewrite ^/$ http://graylogwebcluster/$request_uri? last;
	#SSL
proxy_ssl_certificate /etc/ssl/certs/failover-lb2.lan.crt;
proxy_ssl_certificate_key /etc/ssl/private/failover-lb2.lan.key;
proxy_ssl_ciphers EECDH+CHACHA20:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
proxy_ssl_protocols TLSv1.2 TLSv1.1 TLSv1;
    proxy_ssl_verify        off;
    proxy_ssl_session_reuse on;
#Configuration LoadBalancer Collecte LOG UDP Graylog
stream {
Collecte Rsyslog (Linux)
upstream graylog_upstreams {
least_conn;
server 192.168.153.101:8515;
server 192.168.153.102:8515;
server 192.168.153.103:8515;
upstream graylog_node_upstreams {
least_conn;
server 192.168.153.101:8514;
server 192.168.153.102:8514;
server 192.168.153.103:8514;
Collecte GELF_UDP (Windows) via NXLOG
upstream graylog_udp_log {
least_conn;
server 192.168.153.101:12201;
server 192.168.153.102:12201;
server 192.168.153.103:12201;
Collecte GELF_TCP (Windows) via NXLOG
upstream graylog_tcp_log {
least_conn;
server {
listen 8514 udp;
proxy_pass graylog_node_upstreams;
proxy_responses 0;
proxy_bind $remote_addr transparent;
Linux port Log Listen for clients
server {
listen 8515 udp;
proxy_pass graylog_upstreams;
proxy_responses 0;
server {
listen 12201 udp;
proxy_pass graylog_udp_log;
proxy_responses 0;
server {
listen 12201;
proxy_pass graylog_tcp_log;
proxy_responses 0;
That is quite specific :slight_smile:
If you want to send syslog messages to graylog you should use a Syslog UDP Input and not a GELF UDP Input. Perhaps you have a look into http://docs.graylog.org/en/2.4/pages/getting_started/collect.html
Also you should check if there is anything in the graylog logfiles.
