Hi all,
i can’t undestand how to call an extractor variable inside the body of email notifications.
In legacy alarm callbacks i use for example ${message.fields.from} but in new configuration which is the right syntax?
thanks
Hi all,
thanks
Hello, syntax is the same also in latest version 3.1
Check if you setup correctly Message Backlog parameter in Alerts - Event Definitions - Edit - tab Notification, check field Message Backlog and set to 1. It’s a number of messages to be included in Notification, if 0 no field will be extracted in message.
I use for example this snippet after user connect to switch:
${if backlog}
${foreach backlog message}
User ${message.fields.username} connected to switch ${message.source} from IP ${message.fields.src_ip}
${end}
${end}
You can use same syntax also in Subject field, for example I use:
Graylog event notification: ${event_definition_title} to switch ${foreach backlog message}${message.source}${end} from IP ${foreach backlog message}${message.fields.src_ip}${end}
perfect resolved
thank you very much
