First post but been using graylog for a while and really like it, thanks for the great posts they’ve been so much help. I feel like I’ve missed something so wanted to bring it to the community…
I have a log message coming in and a grok extractor that gets applied on it that should pull out a value, give it a custom field name and store it as a double. I then want to search where the custom field is between two values.
It seems to work as long as the range I search in is 0<= X <= 9.999 but as soon as I use a value like 10 it just returns what seems like random results.
Background
So given a message like this:
16/Nov/2018:15:08:56 +0000 "People who like goat cheese" "3.991"
And a grok extractor like the following:
%{HTTPDATE:timestamp} %{QS:message} "%{BASE10NUM:cheese_eaters:double}"
(Which if I test this in some online grok extractor or via the grok extractor editor in graylog seems to work as expected)
I expect to be able to search like this:
cheese_eaters:>2 AND cheese_eaters:<8
Which does seem to work as expected.
Problem
When I try to search using:
cheese_eaters:>10
I get a number of results, some that are greater than 10 but it seems to be a random selection.
What I’ve tried
Some reading suggested I use a pipeline to write a new field (or override the existing one) as a double, but when I do that using something like the following (note that IRL I’ve used a better condition check, this is just for illustrative purposes)
rule "Convert Values"
has_field("cheese_eaters")
// Initially it was this, but I wasn't convinced it was overwriting the value
set_field("cheese_eaters", to_double($message.cheese_eaters));
// So then I added this to see if it was writing them as expected... field just has '0' in so not convinced he above worked, although does prove the rule was running
set_field("_cheese_eaters", to_double($message.cheese_eaters));
So… yeah I expect to be able to search using a range but when I use a numeric value in the condition of 10 or more I just don’t get expected results… am I missing something obvious? … or not obvious?
