Sample message:
172.28.88.70 - - [18/Sep/2017:14:00:46 -0300] "GET /sisdpu/javax.faces.resource/img/ui-icons_888888_256x240.png.xhtml HTTP/1.1" 304 0 "http://sisdpu.dpu.def.br/sisdpu/javax.faces.resource/_estilo_geral.css.xhtml?ln=css" "Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36" "-"
Extractor created:
"extractor_config": {
"grok_pattern": "%{IPV4:REQUEST_ORIGIN_IP} - - \\[%{SISDPU_TIMESTAMP:TIMESTAMP}\\] \\\"%{HTTP_REQUEST_TYPE:REQUEST_TYPE} %{PATH:GET_PATH} HTTP/1.1\\\" %{INT:HTTP_CODE} %{INT} \\\"%{URI:REQUEST_PAGE_ORIGIN}\\\" %{QS:REQUEST_AGENT} \"-\"",
"named_captures_only": true
"condition_type": "regex",
"condition_value": "^(?<![0-9])(?:(?:[0-1]?[0-9]{1,2}|2[0-4][0-9]|25[0-5])[.](?:[0-1]?[0-9]{1,2}|2[0-4][0-9]|25[0-5])[.](?:[0-1]?[0-9]{1,2}|2[0-4][0-9]|25[0-5])[.](?:[0-1]?[0-9]{1,2}|2[0-4][0-9]|25[0-5]))(?![0-9])"
Before adding, everything is running smoothly. But when I include this extractor, CPU skyrockets, process buffer fills up and I’m getting close to 100% of journal usage. What am I doing so wrong here?
Perhaps this helps a little…?
upgraded nodes, 12 cores, 6GB ram (Xms Xmx set to 3gb). CPU at ~68%, but journal usage still going up… but sometimes, when I try to check node details, this error message shows up on the logs:
2017-09-18T15:24:18.025-03:00 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
at okio.Okio$4.newTimeoutException(Okio.java:230) ~[graylog.jar:?]
at okio.AsyncTimeout.exit(AsyncTimeout.java:285) ~[graylog.jar:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:241) ~[graylog.jar:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:345) ~[graylog.jar:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:217) ~[graylog.jar:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:211) ~[graylog.jar:?]
at okhttp3.internal.http1.Http1Codec.readResponseHeaders(Http1Codec.java:189) ~[graylog.jar:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:75) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67) ~[graylog.jar:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:120) ~[graylog.jar:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:185) ~[graylog.jar:?]
at okhttp3.RealCall.execute(RealCall.java:69) ~[graylog.jar:?]
at org.graylog2.rest.resources.cluster.ClusterJournalResource.get(ClusterJournalResource.java:79) ~[graylog.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_141]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_141]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_141]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_141]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:205) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_141]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_141]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_141]
Caused by: java.net.SocketException: Socket closed
at java.net.SocketInputStream.read(SocketInputStream.java:204) ~[?:1.8.0_141]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_141]
at okio.Okio$2.read(Okio.java:139) ~[graylog.jar:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[graylog.jar:?]
... 51 more
WOOT I’m also getting more than an hour of delay on search!
