ajgltj
1
Just upgraded from 4.0.7 to 4.1.0. Now I can’t export CSV from search results:
gsmith
(GSmith)
2
Did you check if Graylog has access on you server. Sometimes when I upgrade I have to execute something like this
chown graylog:graylog -R /etc/graylog
Does the user executing CSV download have permissions?
ajgltj
3
Hmm, let me try that.
Yes, I have permissions, I have the admin role.
ajgltj
4
That did not work, unfortunately. (unless this needs a service restart?)
ajgltj
5
Band-aid fix found???
Tried exporting a CSV on Firefox and this prompt came up. Clicked OK and the download went through.
Chrome, however, won’t go through with the export.
gsmith
(GSmith)
6
You dont have anything in the way like firewall or selinux?
Hi, the reason for the prompt and changed behaviour is this PR fixing the export for huge file sizes:
ajgltj
8
Thank you! I’ve never applied fixes like this before - how do I merge this with my current Graylog instance?
