hello community!
I’ve a question/problem. When I export data to a CSV it stops after 150MB. Is this a restriction of the community version? Or ist somewhere a parameter for the limitation?
thanks for your help!
hello community!
What version of Graylog and Elasticsearch/OpenSearch are you using?
Do you see any errors either in the Graylog UI or in server.log? Do you know how many log messages are included in the export?
What export method are you using? For example, via the API, via the message table export?
Thanks for the reply. I have fixed the issue with more RAM of the machine.
