Excluding logs using pipeline
I’m having issues excluding some logs from graylog, as they are quite spammy.
The messages I’m trying to exclude are from SNMP.
application_name
snmpd
facility
system daemon
from_syslog
true
level
6
message
Connection from UDP: [10.85.1.30]:64093->[10.75.3.25]
process_id
2497
source
hermes
timestamp
2018-10-22T04:50:06.898Z
They all have this portion of the message:
Here’s what I have so far;
rule “remove spammy snmp”
has_field (“message”) && to_string($message.message) == “Connection from UDP: [10.85.1.30]”
drop_message();
Unfortunately not working, which I assume I haven’t got the right match requirements.
Can someone please give me an example on how this would work?
Thanks for your time!
Hi @rosstola
The when condition you are performing in that rule is an exact match however, the complete contents of the message field (in the given example) is " Connection from UDP: [10.85.1.30]:64093->[10.75.3.25]"
I would suggest changing your rule to something similar to the below:
  has_field ("message") &&
  contains(to_string($message.message), "Connection from UDP: [10.85.1.30]")
  drop_message();
Thanks.
