Magneton
(Jake Smith)
1
HI All,
Is it possible to use the following in a lookup tale
Get-PSDrive | where {$_.Provider -like “Microsoft.PowerShell.Core\FileSystem”}| ft Name,Root
This is a powershell one liner to find c:\ drive etc.
I want to use it in a lookup table, but what about the quotes, wont they break the csv file?
Cheers
Jake
jochen
(Jochen)
2
It’s possible to configure the quote character in the CSV File data adapter:
Magneton
(Jake Smith)
3
Hi Jochen,
Can you use an obscure character such as ` or ^ as your quote character as the strings in the csv have both single and double quotes?
Cheers
Jake
Magneton
(Jake Smith)
4
Hi Jochen,
Or maybe { as a quote character?
Jake
jochen
(Jochen)
5
Sure, any ASCII character which isn’t part of the quoted values should work.
It’s possible, but it doesn’t look good.
id,value1,value2
1,{some quoted value{,{another quoted value{
Magneton
(Jake Smith)
6
Hi Jochen,
Here is an example which i know looks horrid but works with [ as quote character and ; as a separator
[Command[;[Category[
[Get-ChildItem Env: | ft Key,Value[;[Privilege Escalation[
[$env:UserName[,[Privilege Escalation[
[Get-LocalUser | ft Name,Enabled,LastLogon[;[Privilege Escalation[
[Get-ChildItem C:\Users -Force | select Name[;[Privilege Escalation[
[Get-LocalGroup | ft Name[;[Privilege Escalation[
[Get-LocalGroupMember Administrators | ft Name, PrincipalSource[;[Privilege Escalation[
[Get-ItemProperty -Path 'Registry::HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\WinLogon' | select "Default*"[;[[Privilege Escalation[
I posted so that if someone else needs similar functionality they can see how to do it.
Cheers
Jake
