2017-04-25 10:08:30,890 INFO : org.elasticsearch.cluster.service - [graylog-4e068bf7-0ed3-4164-9b89-5f925b328582] detected_master {Jean-Paul Beaubier}{pVRO1qVbTCekJTK6GoXtLw}{127.0.0.1}{127.0.0.1:9300}, added {{Jean-Paul Beaubier}{pVRO1qVbTCekJTK6GoXtLw}{127.0.0.1}{127.0.0.1:9300},}, reason: zen-disco-receive(from master [{Jean-Paul Beaubier}{pVRO1qVbTCekJTK6GoXtLw}{127.0.0.1}{127.0.0.1:9300}])
2017-04-25 10:08:31,739 WARN : org.glassfish.jersey.internal.Errors - The following warnings have been detected: WARNING: Unknown HK2 failure detected:
MultiException stack 1 of 1
com.google.inject.ProvisionException: Unable to provision, see the following errors:
1) Error injecting constructor, java.lang.IllegalStateException: Unable to find web interface assets. Maybe the web interface was not built into server?
at org.graylog2.web.PluginAssets.<init>(PluginAssets.java:48)
while locating org.graylog2.web.PluginAssets
for the 1st parameter of org.graylog2.web.IndexHtmlGenerator.<init>(IndexHtmlGenerator.java:39)
at org.graylog2.web.IndexHtmlGenerator.class(IndexHtmlGenerator.java:39)
while locating org.graylog2.web.IndexHtmlGenerator
1 error
at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1028)
at org.jvnet.hk2.guice.bridge.internal.GuiceServiceHk2Bean.create(GuiceServiceHk2Bean.java:114)
at org.jvnet.hk2.internal.SystemDescriptor.create(SystemDescriptor.java:479)
at org.jvnet.hk2.guice.bridge.internal.GuiceScopeContext.findOrCreate(GuiceScopeContext.java:75)
at org.jvnet.hk2.internal.Utilities.createService(Utilities.java:2022)
at org.jvnet.hk2.internal.ServiceHandleImpl.getService(ServiceHandleImpl.java:114)
at org.jvnet.hk2.internal.ServiceLocatorImpl.getService(ServiceLocatorImpl.java:695)
at org.jvnet.hk2.internal.ThreeThirtyResolver.resolve(ThreeThirtyResolver.java:78)
at org.jvnet.hk2.internal.ClazzCreator.resolve(ClazzCreator.java:212)
at org.jvnet.hk2.internal.ClazzCreator.resolveAllDependencies(ClazzCreator.java:229)
at org.jvnet.hk2.internal.ClazzCreator.create(ClazzCreator.java:358)
at org.jvnet.hk2.internal.SystemDescriptor.create(SystemDescriptor.java:487)
at org.jvnet.hk2.internal.SingletonContext$1.compute(SingletonContext.java:83)
at org.jvnet.hk2.internal.SingletonContext$1.compute(SingletonContext.java:71)
at org.glassfish.hk2.utilities.cache.Cache$OriginThreadAwareFuture$1.call(Cache.java:97)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at org.glassfish.hk2.utilities.cache.Cache$OriginThreadAwareFuture.run(Cache.java:154)
at org.glassfish.hk2.utilities.cache.Cache.compute(Cache.java:199)
at org.jvnet.hk2.internal.SingletonContext.findOrCreate(SingletonContext.java:122)
at org.jvnet.hk2.internal.ServiceHandleImpl.getService(ServiceHandleImpl.java:88)
at org.glassfish.jersey.internal.inject.Providers.getAllRankedProviders(Providers.java:247)
at org.glassfish.jersey.server.ApplicationHandler.getProcessingProviders(ApplicationHandler.java:757)
at org.glassfish.jersey.server.ApplicationHandler.initialize(ApplicationHandler.java:537)
at org.glassfish.jersey.server.ApplicationHandler.access$500(ApplicationHandler.java:184)
at org.glassfish.jersey.server.ApplicationHandler$3.call(ApplicationHandler.java:350)
at org.glassfish.jersey.server.ApplicationHandler$3.call(ApplicationHandler.java:347)
at org.glassfish.jersey.internal.Errors.process(Errors.java:315)
at org.glassfish.jersey.internal.Errors.process(Errors.java:297)
at org.glassfish.jersey.internal.Errors.processWithException(Errors.java:255)
at org.glassfish.jersey.server.ApplicationHandler.<init>(ApplicationHandler.java:347)
at org.glassfish.jersey.server.ApplicationHandler.<init>(ApplicationHandler.java:311)
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.<init>(GrizzlyHttpContainer.java:337)
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpServerFactory.createHttpServer(GrizzlyHttpServerFactory.java:189)
at org.graylog2.shared.initializers.JerseyService.setUp(JerseyService.java:342)
at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:224)
at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:141)
at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62)
at com.google.common.util.concurrent.Callables$4.run(Callables.java:122)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.IllegalStateException: Unable to find web interface assets. Maybe the web interface was not built into server?
at org.graylog2.web.PluginAssets.<init>(PluginAssets.java:73)
at org.graylog2.web.PluginAssets$$FastClassByGuice$$f971ec83.newInstance(<generated>)
at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:111)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:90)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:268)
at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:38)
at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:62)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:110)
at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1092)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:194)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:41)
at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1019)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1085)
at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1015)
... 40 more
