I know this error org.graylog2.periodical.NodePingThread - Did not find meta info of this node. Re-registering. is due to time syncing but can anyone please give me a step by step procedure to solve this using ntp ? I am using Kubernetes for the graylog cluster.
ERROR : org.graylog2.periodical.NodePingThread - Did not find meta info of this node. Re-registering
Hey @AkashKrDutta,
normally, every linux distro comes with NTP installed by default. It seems that your network does not allow any NTP connections to the servers in /etc/ntp.conf. Do you have any internal NTP server, that you can set inside the /etc/ntp.conf file?
Another way with docker seems to be this:
Edit: Something that I just found:
If the time drift between your servers is not to large and stays constant, setting stale_master_timeout in the Graylog config could help.
Greetings - Phil
