ERROR: org.graylog2.inputs.codecs.GelfCodec - Could not parse JSON, first 400 characters: A?H?S?>N?)?}a+&?
Hi Team ,
I am getting below error,
What you are sending to the GELF input is not properly formatted… I can’t tell anything else about what is going on though… you would need to post more information… It’s all a black box until you tell us what
you have, and how you are doing it. Posting text wherever possible is better than text in a picture.
NOTE: moved the post to Graylog Central where questions are asked.
Here are posts on how to ask questions in the forum…
@tmacgbay sending below data to graylog using java utility
	"version": "1.1",
	"host": "example.org",
	"short_message": "A short message that helps you identify what is going on",
	"full_message": "Backtrace here\n\nmore stuff",
	"timestamp": 1385053862.3072,
	"level": 1,
	"_user_id": 9001,
	"_some_info": "foo",
	"_some_env_var": "bar"
and getting below exception
2023-01-05 07:01:39,904 ERROR: org.graylog2.shared.buffers.processors.DecodingProcessor - Unable to decode raw message RawMessage{id=cd976de0-8cc6-11ed-a312-0242ac130004, messageQueueId=464, codec=gelf, payloadSize=37, timestamp=2023-01-05T07:01:39.902Z, remoteAddress=/172.19.0.1:41316} on input <63b5746f2760d74efd1355d9>.
graylog_1        | 2023-01-05 07:01:39,904 ERROR: org.graylog2.shared.buffers.processors.DecodingProcessor - Error processing message RawMessage{id=cd976de0-8cc6-11ed-a312-0242ac130004, messageQueueId=464, codec=gelf, payloadSize=37, timestamp=2023-01-05T07:01:39.902Z, remoteAddress=/172.19.0.1:41316}
graylog_1        | com.fasterxml.jackson.core.JsonParseException: Unrecognized t': was expecting ('true', 'false' or 'null')
graylog_1        |  at [Source: (String)"$
graylog_1        |
                  "; line: 1, column: 19]
graylog_1        |      at com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:1804) ~[graylog.jar:?]
graylog_1        |      at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:703) ~[graylog.jar:?]
graylog_1        |      at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._reportInvalidToken(ReaderBasedJsonParser.java:2853) ~[graylog.jar:?]
graylog_1        |      at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._handleOddValue(ReaderBasedJsonParser.java:1899) ~[graylog.jar:?]
graylog_1        |      at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextToken(ReaderBasedJsonParser.java:757) ~[graylog.jar:?]
graylog_1        |      at com.fasterxml.jackson.databind.ObjectMapper._readTreeAndClose(ObjectMapper.java:4043) ~[graylog.jar:?]
graylog_1        |      at com.fasterxml.jackson.databind.ObjectMapper.readTree(ObjectMapper.java:2552) ~[graylog.jar:?]
graylog_1        |      at org.graylog2.inputs.codecs.GelfCodec.decode(GelfCodec.java:130) ~[graylog.jar:?]
graylog_1        |      at org.graylog2.shared.buffers.processors.DecodingProcessor.processMessage(DecodingProcessor.java:156) ~[graylog.jar:?]
graylog_1        |      at org.graylog2.shared.buffers.processors.DecodingProcessor.onEvent(DecodingProcessor.java:94) [graylog.jar:?]
graylog_1        |      at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:95) [graylog.jar:?]
graylog_1        |      at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:49) [graylog.jar:?]
graylog_1        |      at com.lmax.disruptor.WorkProcessor.run(WorkProcessor.java:143) [graylog.jar:?]
graylog_1        |      at com.codahale.metrics.InstrumentedThreadFactory$InstrumentedRunnable.run(InstrumentedThreadFactory.java:66) [graylog.jar:?]
graylog_1        |      at java.lang.Thread.run(Thread.java:750) [?:1.8.0_332]
graylog_1        | 2023-01-05 07:01:39,905 ERROR: org.graylog2.inputs.codecs.GelfCodec - Could not parse JSON, first 400 characters:  ?q|???q,f???M?:?#K??q?    ?????H
graylog_1        | com.fasterxml.jackson.core.JsonParseException: Unrecognized token '?q': was expecting ('true', 'false' or 'null')
graylog_1        |  at [Source: (String)" ?q|???q,f???M?:?#K??q?        ?????H"; line: 1, column: 5]
graylog_1        |      at org.graylog2.inputs.codecs.GelfCodec.decode(GelfCodec.java:130) [graylog.jar:?]
graylog_1        |      at org.graylog2.shared.buffers.processors.DecodingProcessor.processMessage(DecodingProcessor.java:156) [graylog.jar:?]
graylog_1        | 2023-01-05 07:01:39,905 ERROR: org.graylog2.shared.buffers.processors.DecodingProcessor - Unable to decode raw message RawMessage{id=cd9794f0-8cc6-11ed-a312-0242ac130004, messageQueueId=465, codec=gelf, payloadSize=33, timestamp=2023-01-05T07:01:39.903Z, remoteAddress=/172.19.0.1:41316} on input <63b5746f2760d74efd1355d9>.
graylog_1        | 2023-01-05 07:01:39,905 ERROR: org.graylog2.shared.buffers.processors.DecodingProcessor - Error processing message RawMessage{id=cd9794f0-8cc6-11ed-a312-0242ac130004, messageQueueId=465, codec=gelf, payloadSize=33, timestamp=2023-01-05T07:01:39.903Z, remoteAddress=/172.19.0.1:41316}
The error states there is a 't' at line 1 column 19 where it is expecting the true, false or null it then says Unrecognized token '?q' with notes around it with things like characters: ?q|???q,f???M?:?#K??q? ?????H
I don’t think the GELF Input is receiving what you think you are sending. You can use TCPDump on the port (There are other post on the forum for how if you need) or you can change the receiving input to RAW to get just what is being sent to it and test out the results.
NOTE: I used the forum tool </> to reformat your posts to make them more easily readable.
