Error notification Graylog 3.2
Hi !
I wanted to know if it’s possible to be notified by mail when there are errors on graylog. On the web int this error appears as a red dot
he @fred
did you refer to problems of Graylog itself? Like expired license or similar?
That is currently not possible and you would need to have your external monitoring checking the API for the existence of alerts.
In my case there was a notification “An input has failed to start” i solve the problem but i wanted to know if its possible to be notified for this type of notification without check on the web int
