Before you post: Your responses to these questions will help the community help you. Please complete this template if you’re asking a support question. Don’t forget to select tags to help index your topic!
Error Massage
OpenSearchException[OpenSearch exception [type=illegal_argument_exception, reason=Limit of total fields [1000] has been exceeded]]
OS Information: AlmaLinux
Package Version: Graylog 6.3.5+ & Datanode
Does a simple GET work ? curl “localhost:9200/graylog_14/_settings”
Maybe add “-v” to curl to get more details.
I handle this settings with a template to apply it to all indices (only the new ones).
Finally I recommend to split your logs in separate indices, for example one for windows, one for firewalls… And maybe you can rotate your indices more often (for example every 8 hours). It will reduce the number of fields per index.
SSL certificate problem: unable to get local issuer certificate
closing connection #0
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: curl - SSL CA Certificates
This is my first time using Graylog, and I’d like to ask how to route traffic to other indices. I usually find the relevant information in the detfault stream and then route it to other streams using conditions (such as IP). Currently, whenever I syslog to Graylog through the firewall, I immediately get an error message saying “over 1000 filed entries”.
Add “-k” to your curl command to skip TLS checks if you don’t have the CA.
To route logs into indices you need to use Streams. When you configure a Stream you can choose to route filtered logs into a specific index and to delete them from the default index.
it will be pop up the URL rejected. I didn’t know which problem with datanode….
[root@nitcgl gladmin]# curl -X PUT -k -u admin:password \ “https://localhost:9200/graylog_15/_settings” \ -H ‘Content-Type: application/json’ \ -d ‘{“index.mapping.total_fields.limit”: 5000}’
curl: (3) URL rejected: Malformed input to a URL function
and the other hand, the error happen on deault stream, so I can’t route to another index….
If you have special characters in the password, you need to use simple quotes:
-u ‘admin:password’
Regarding the default stream you can remove logs from it, when you create a Stream choose an index (other than “Default index set”) and check “Removes matches from ‘Default Stream’.
However if a log matches multiple Streams linked with multiple indices, it will be duplicated in all indices.
