ERROR [GrokPatternRegistry] Unable to load grok pattern
after switching to a newer version of graylog, a source does not send logs. It only sends the old one. After I removed the logs from the server, I noticed that the error “ERROR [GrokPatternRegistry] Unable to load grok pattern Alert Level” appeared, can someone help me to correct the error
Need some more clarity to your post, please provide more relevant information. Source is not sending logs or is it sending and Graylog not receiving? what kind of logs from what kind of device, how is it set up, what is the Input you are using… are you seeing anything in the Graylog logs? Where are you seeing the GROK error coming from?
You can find more on how to ask questions with helpful information here and here. It includes things like posting code with the </> forum tool to make code/logs more readable and how to pull config files without including all the comments (Commented lines starting with #) Also making sure you are obfuscating any private information…
We no nothing about your setup so any relevant information you can provide including steps you have tried are very helpful for figuring out how to solve the incident!
