Error Couldn't refresh data adapter
One of our services broke down and sent a lot of messages, caused a very heavy load, we decided not to wait for the whole message to be parsed and deleted everything from the graylog-server/journal/messagejournal-0 directory/
After starting graylog-server, we see an error in the logs and the outgoing message is 0
graylog-server. 3.3.11-1
mongodb-org-server. 3.6.23-1
elasticsearch. 5.6.16-1
OracleLinux 7.9
ERROR [LookupDataAdapter] Couldn’t refresh data adapter abuse-ch-ransomware-ip/5a71d9d0359a8b04c86c1932/@67f7b846
at okhttp3.internal.http2.Http2Stream$StreamTimeout.newTimeoutException(Http2Stream.java:678) ~[graylog.jar:?]
at okhttp3.internal.http2.Http2Stream$StreamTimeout.exitAndThrowIfTimedOut(Http2Stream.java:686) ~[graylog.jar:?]
at okhttp3.internal.http2.Http2Stream.takeHeaders(Http2Stream.java:154) ~[graylog.jar:?]
at okhttp3.internal.http2.Http2ExchangeCodec.readResponseHeaders(Http2ExchangeCodec.java:136) ~[graylog.jar:?]
at okhttp3.internal.connection.Exchange.readResponseHeaders(Exchange.java:115) ~[graylog.jar:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:94) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[graylog.jar:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:43) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[graylog.jar:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[graylog.jar:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[graylog.jar:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[graylog.jar:?]
at okhttp3.RealCall.execute(RealCall.java:81) ~[graylog.jar:?]
at org.graylog2.lookup.adapters.dsvhttp.HTTPFileRetriever.fetchFile(HTTPFileRetriever.java:76) ~[graylog.jar:?]
at org.graylog2.lookup.adapters.dsvhttp.HTTPFileRetriever.fetchFileIfNotModified(HTTPFileRetriever.java:60) ~[graylog.jar:?]
at org.graylog.plugins.threatintel.adapters.abusech.AbuseChRansomAdapter.loadData(AbuseChRansomAdapter.java:130) ~[?:?]
at org.graylog.plugins.threatintel.adapters.abusech.AbuseChRansomAdapter.doRefresh(AbuseChRansomAdapter.java:125) ~[?:?]
at org.graylog2.plugin.lookup.LookupDataAdapter.refresh(LookupDataAdapter.java:109) ~[graylog.jar:?]
at org.graylog2.lookup.LookupDataAdapterRefreshService.lambda$schedule$0(LookupDataAdapterRefreshService.java:142) ~[graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_282]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_282]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_282]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_282]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_282]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_282]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_282]
Hello @ec10
I don’t think this error is about your journal , it referring to you Data Adaptor called abuse-ch-ransomware-ip
You may want to look at these posts.
This was concerning about your error here…
Hope that helps
