Enteprise Plugin / Small Business
Hi guys,
I installed Graylog Open ( 6) on Ubuntu Server 22.0.4.4.
I used the doc here
https://go2docs.graylog.org/current/downloading_and_installing_graylog/ubuntu_installation.html?tocpath=Installing%20Graylog|Operating%20System%20Packages|_____1
I want to use Graylog small bussines as described here
Step 1 “Install Graylog Open via our DEB”
That’s what I did successfully
Step 2: Find you Cluster ID
Got it - no problem.
Step 3 , that’s where I stumble
Where to download this mystique plugin ??
I guess it’s a jar-file, that’s what I could read in some older posts.
Any ideas ?
Thank you, :pray:
Jochen
Did you install the package graylog-enterprise or graylog-server, if you installed enterprise then yoy are done. If you installed server then just install enterprise over it and it will upgrade it.
Thank you, that solved it for me.
The instructions on the offical Grayolg websites are a bit confusing for a graylog newbie. Anyway, now it licensed and my old config still works.
Hey there! I’m having the same issue, but my setup is on kubernetes and therefore i’m not using the regular graylog package avaible on the website. I thought that maybe the docker container would run with the enterprise plugin installed by default. But apparently it is not so i’m trying to download the package manually and then send it to a volume inside my k8s environment. Is there a better solution? What am i missing out?
Hello and welcome @rafitox
The Docker image for Graylog Enterprise can be found here.
Oh thanks a lot! I didn’t realize there were separated repositories on docker hub. I’m quite new on graylog =) i appreciate your help and your time
