I’m new today to learning about Gray log and read that “As a (en embedded Elasticsearch) node you can send it in native format, and it is fast.” I understand embedded ES was now deprecated - does Graylog still use it, or is this statement (from the architecture deep dive) out of date?
As Graylog has switched from an embedded Elasticsearch node client to a lightweight HTTP client in version 2.3, please check the upgrade notes how to migrate your configuration if you are switching from an earlier version.
https://docs.graylog.org/en/latest/pages/configuration/elasticsearch.html
Current Graylog version is 3.3.4 (with no apparent changes from 3.3.3 :P)
