Elasticsearch cluster is RED - Solved
Here is a partial output of http://172.20.32.95:9200/_cat/shards
moadmin.php            1 p STARTED         0   159b 172.20.32.95 Robert Bruce Banner
moadmin.php            1 r UNASSIGNED
moadmin.php            3 p STARTED         0   159b 172.20.32.95 Robert Bruce Banner
moadmin.php            3 r UNASSIGNED
moadmin.php            4 p STARTED         0   159b 172.20.32.95 Robert Bruce Banner
moadmin.php            4 r UNASSIGNED
moadmin.php            2 p STARTED         0   159b 172.20.32.95 Robert Bruce Banner
moadmin.php            2 r UNASSIGNED
moadmin.php            0 p STARTED         0   159b 172.20.32.95 Robert Bruce Banner
moadmin.php            0 r UNASSIGNED
servlet                1 p STARTED         0   159b 172.20.32.95 Robert Bruce Banner
servlet                1 r UNASSIGNED
servlet                3 p STARTED         0   159b 172.20.32.95 Robert Bruce Banner
servlet                3 r UNASSIGNED
servlet                2 p STARTED         0   159b 172.20.32.95 Robert Bruce Banner
servlet                2 r UNASSIGNED
servlet                4 p STARTED         0   159b 172.20.32.95 Robert Bruce Banner
servlet                4 r UNASSIGNED
servlet                0 p STARTED         0   159b 172.20.32.95 Robert Bruce Banner
servlet                0 r UNASSIGNED
Here is the output of http://172.20.32.95:9200/_cluster/health?pretty
  "cluster_name" : "graylog",
  "status" : "yellow",
  "timed_out" : false,
  "number_of_nodes" : 2,
  "number_of_data_nodes" : 1,
  "active_primary_shards" : 244,
  "active_shards" : 244,
  "relocating_shards" : 0,
  "initializing_shards" : 0,
  "unassigned_shards" : 244,
  "active_shards_percent_as_number" : 50.0
So from what I can see each shard within each index has a primary and a replica. The replica is UNASSIGNED. For each index in the system, we see this same pattern. Is there a way to fix it?
I am new to graylog and it is a very sweet product. Thanks in advance for any help or suggestions!
Dave.
What exactly is the issue you’re trying to solve?
Regarding the state of your Elasticsearch cluster, I have the following observations:
  • The index names from the cat shards output look like you’re running Elasticsearch on a public network interface facing the Internet and someone performed an automatic scan against it which created these strange indices (“servlet”, “moadmin.php”).
  • With only 1 data node, having replicas doesn’t make sense.
I’m running Graylog and did a appliance installation. We have used it for a few months and why I raise the question is that Graylog is reporting Elasticsearch cluster is yellow. Shards: 4 active, 0 initializing, 0 relocating, 4 unassigned.
Does this answer your question?
You only have 1 Elasticsearch data node so that replica shards cannot be assigned anywhere.
By definition, this makes the cluster health state YELLOW (see http://docs.graylog.org/en/2.2/pages/configuration/elasticsearch.html#yellow).
Either reduce the number of replica shards to 0 or add (at least) another Elasticsearch node to your Elasticsearch cluster.
Look this.
Green!!!
Thanks guys! You are all very helpful. Hope you all have a great week.
Just keep in mind that you have no resilience against node failures whatsoever if you only run 1 Elasticsearch data node and have no replicas.
