So I spun up the newest version of graylog for my house on:
$ uname -a
Linux graylog 5.10.0-24-amd64 #1 SMP Debian 5.10.179-5 (2023-08-08) x86_64 GNU/Linux
Everything is local, nothing special or fancy. It’s been working fine for about 3 months now. Recently I checked the status and found my Elasticsearch cluster graylog is yellow . I do not know when or why this happened, so I started to educate myself and found this information after digging around:
curl -XGET localhost:9200/_cat/shards?h=index,shard,prirep,state,unassigned.reason| grep UNASSIGNED
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 2835 100 2835 0 0 74605 0 --:--:-- --:--:-- --:--:-- 74605
.opensearch-sap-pre-packaged-rules-config 0 r UNASSIGNED CLUSTER_RECOVERED
.plugins-ml-config 0 r UNASSIGNED CLUSTER_RECOVERED
.opensearch-sap-log-types-config 0 r UNASSIGNED CLUSTER_RECOVERED
Ummm ok, what the heck does that mean besides I have 3 indexes that are unassigned. Doesn’t really tell me why…soooo I dug some more.
curl -XGET 'localhost:9200/_cluster/allocation/explain'
{"index":".opensearch-sap-pre-packaged-rules-config","shard":0,"primary":false,"current_state":"unassigned","unassigned_info":{"reason":"CLUSTER_RECOVERED","at":"2023-08-17T17:28:41.278Z","last_allocation_status":"no_attempt"},"can_allocate":"no","allocate_explanation":"cannot allocate because allocation is not permitted to any of the nodes","node_allocation_decisions":[{"node_id":"vs8XWHBRSqCucxyMWhn2RA","node_name":"graylog","transport_address":"192.168.10.105:9300","node_attributes":{"shard_indexing_pressure_enabled":"true"},"node_decision":"no","deciders":[{"decider":"same_shard","decision":"NO","explanation":"a copy of this shard is already allocated to this node [[.opensearch-sap-pre-packaged-rules-config][0], node[vs8XWHBRSqCucxyMWhn2RA], [P], s[STARTED], a[id=s9bULvoCSmm-RmGxJnrDRA]]"}]}]}
OK - don’t really care. Maybe it was because I rolled back a vm snapshot, maybe it was an update. No clue how this happened but trust me, it was not always there. Maybe it was related to the hypervisor input I added that seemed to have too many messages and flood the system. So I deleted the hypervisor input, index, everything about it. That did not solve the problem, so, I decided to just delete the errors above after a lot more reading.
curl -XDELETE http://localhost:9200/.opensearch-sap-pre-packaged-rules-config
curl -XDELETE http://localhost:9200/.plugins-ml-config
curl -XDELETE http://localhost:9200/.opensearch-sap-log-types-config
Then I checked again to make sure they were really gone (and they were)
Rebooted the server and, ummm yeah, they instantly came back. HELP!
Joy, this platform just said “new users can only post 1 pic” well…instead of many pictures showing all the details, you get one ![]()
