Drop events using the sidecar collector
I am having trouble establishing a configuration to remove noise from my DCS. For example this configuration where I try to drop logs from a specific user:
# Needed for Graylog
fields_under_root: true
fields.source: ${sidecar.nodeName}
output.logstash:
  hosts: ["10.0.0.53:5044"]
path:
tags:
  - windows
winlogbeat:
  event_logs:
    - name: Application
    - name: System
    - name: Security
      processors:
        - drop_event:
                when.and:
                 contains:
                     event_data_TargetUserName: sauser
    - name: Microsoft-Windows-Sysmon/Operational
    - name: Windows PowerShell
    - name: DNS Server
    - name: Microsoft-Windows-PrintService/Admin
    - name: Microsoft-Windows-TerminalServices-LocalSessionManager/Admin
    - name: Microsoft-Windows-TerminalServices-LocalSessionManager/Operational
    - name: Microsoft-Windows-TerminalServices-RemoteConnectionManager/Admin
    - name: Microsoft-Windows-TerminalServices-RemoteConnectionManager/Operational
and this:
output.logstash:
path:
tags:
  - windows
winlogbeat:
  event_logs:
    - name: Application
    - name: System
    - name: Security
      processors:
        - drop_event.when.or:
            when:
              and:
                - or:
                    - equals.event_data_ProcessName: C:\Program Files\Graylog\sidecar\graylog-sidecar.exe
                - or:
                    - equals.event_data_TargetUserName: user1
                    - equals.event_data_TargetUserName: user2
                - or:
                    - equals.event_data_SubjectUserName: user2
    - name: DNS Server
None of the configurations had the expected effect. Could someone help me create a useful file?
Hello && Welcome @maiconjs
Perhaps this post may help
Or some type of configuration like this.
winlogbeat.event_logs:
  - name: Application
    ignore_older: 72h
  - name: System
  - name: Security
    event_id: 4625, 4626
    event_id: 400, 403, 600, 800
  - name: Microsoft-Windows-PowerShell/Operational
    event_id: 4103, 4104, 4105, 4106
Thanks for the welcome. I tried the suggested configuration from the link, but I still keep getting logs from a wildcard user.
Hello
What kind of message do you want ? Can you explain this in greater detail?
Also what does you current configurations look like.
In my DC I have some users that are used by some applications, for reading and operations in the environment (e.g. Kaspersky Endpoint). In the environment I have around 270 stations with windows and I get several logs for each authentication of this service. I need to reduce the noise by removing the logs for these wildcard users.
First you need to know the difference between Service Account SID’s and User account SID’s. What needs to happen is find each SID “A security identifier (SID) is used to uniquely identify a security principal or security group. Security principals can represent any entity that can be authenticated by the operating system, such as a user account, a computer account, or a thread or process that runs in the security context of a user or computer account.”
Then you need to filter out what you want and drop the rest.
Example:
Administrator       S-1-5-21-2720602528-101527634-271158134-500
DefaultAccount      S-1-5-21-2720602528-101527634-271158134-503
Guest               S-1-5-21-2720602528-101527634-271158134-501
Please look here.
I am currently using this configuration, based on this link:
output.logstash:
path:
# The amount of time to wait for all events to be published when shutting down.
winlogbeat.shutdown_timeout: 30s
# A list of entries (called dictionaries in YAML) that specify which event logs to monitor.
  # Application Crashes: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Application-Crashes.xml
  - name: Application
    event_id: 1000, 1002
    ignore_older: 24h
    level: error
    provider:
      - Application Error
      - Application Hang
  - name: Application
    event_id: 1001
    ignore_older: 24h
    level: info
    provider:
      - Windows Error Reporting
  # emet: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/EMET.xml
  - name: Application
    event_id: 1, 2
    level: warning, error
    provider:
      - EMET
  # Account Lockout: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Account-Lockout.xml
  - name: Security
    event_id: 4740
    level: info
    ignore_older: 24h
    provider:
      - Microsoft-Windows-Security-Auditing
  # event log diagnostics: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Event-Log-Diagnostics.xml
  - name: System
    ignore_older: 24h
    provider:
      - Microsoft-Windows-Eventlog
  - name: Security
    ignore_older: 24h
    event_id: 1100, 1104, 1105, 1108
  # explicit credentials: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Explicit-Credentials.xml
  - name: Security
    level: info
    ignore_older: 24h
    provider:
  # Account Management: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Account-Management.xml
  - name: Security
    event_id: 4627, 4703, 4704, 4705, 4720, 4737-4739, 4780-4782, 4793, 4794, 4798, 4799, 5376, 5377
    ignore_older: 24h
  - name: Security
    event_id: 4722-4735
    ignore_older: 24h
  - name: Security
    event_id: 4741-4753
    ignore_older: 24h
  - name: Security
    event_id: 4754-4767
    ignore_older: 24h
  # Active Directory: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Active-Directory.xml
  - name: Security
    event_id: 4662, 14080, 5136, 5137, 5178, 5139, 5141, 4713, 4706, 4707, 4716, 4717, 4718, 4739, 4864, 4865, 4866, 4867
    ignore_older: 24h
  # Authentication: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Authentication.xml
  - name: Security
    #event_id: 4624-4626, 4634, 4647, 4649, 4672, 4675, 4774-4779, 4800-4803, 4964, 5378
    event_id: 4624-4626, 4647, 4649, 4675, 4774-4779, 4800-4803, 4964, 5378
    ignore_older: 24h
  # autoruns: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Autoruns.xml
  # make sure to set up the scheduled autoruns service
  - name: Autoruns
    ignore_older: 24h
  # bits: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Bits-Client.xml
  - name: Microsoft-Windows-Bits-Client/Operational
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 3
          - equals.winlog.event_id: 5
          - equals.winlog.event_id: 61
          - equals.winlog.event_id: 16403
  # certificate authority: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Certificate-Authority.xml
  - name: Security
    event_id: 4886, 4887, 4888
    ignore_older: 24h
  # code integrity: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Code-Integrity.xml
  - name: Microsoft-Windows-CodeIntegrity/Operational
    event_id: 3001, 3002, 3003, 3004, 3010, 3023
    ignore_older: 24h
    level: error, warning
    provider:
      - Microsoft-Windows-CodeIntegrity
  - name: Security
    event_id: 5038, 6281, 6410
    ignore_older: 24h
    level: info
    provider:
  # drivers: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Drivers.xml
  - name: System
    event_id: 219
    ignore_older: 24h
    level: warning
    provider:
      - Microsoft-Windows-Kernel-PnP
  - name: Microsoft-Windows-DriverFrameworks-UserMode/Operational
    event_id: 2004
    ignore_older: 24h
  - name: System
    level: "critical, error"
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 7000
          - equals.winlog.event_id: 7001
          - equals.winlog.event_id: 10016
          - equals.winlog.event_id: 24629
          - equals.winlog.event_id: 10010
          - equals.winlog.event_id: 11060
          - equals.winlog.event_id: 41
          - equals.winlog.event_id: 124
          - equals.winlog.event_id: 34
  # As requested by our external CISO service
  - name: ForwardedEvents
    tags: [forwarded]
    processors:
      - script:
          when.equals.winlog.channel: Security
          lang: javascript
          file: C:\Program Files\Graylog\sidecar\module\security\config\winlogbeat-security.js
      - script:
          when.equals.winlog.channel: Microsoft-Windows-Sysmon/Operational
          lang: javascript
          file: C:\Program Files\Graylog\sidecar\module\sysmon\config\winlogbeat-sysmon.js
      - script:
          when.equals.winlog.channel: Windows PowerShell
          lang: javascript
          file: C:\Program Files\Graylog\sidecar\module\powershell\config\winlogbeat-powershell.js
      - script:
          when.equals.winlog.channel: Microsoft-Windows-PowerShell/Operational
          lang: javascript
  - name: Microsoft-Windows-BitLocker/BitLocker Operational
    level: "critical, error, warning"
    ignore_older: 24h
  - name: Microsoft-Windows-BitLocker/BitLocker Management
    ignore_older: 24h
  - name: Microsoft-Windows-BitLocker-DrivePreparationTool/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-BitLocker-DrivePreparationTool/Admin
    ignore_older: 24h
  - name: Microsoft-Windows-DSC/Operational
    ignore_older: 24h
    event_id: 4103, 4105, 4106
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 4104
          - equals.winlog.event_id: 4100
          - equals.winlog.event_id: 32784
  - name: Microsoft-Windows-PowerShell/Admin
    ignore_older: 24h
  - name: Microsoft-Windows-PowerShell-DesiredStateConfiguration-FileDownloadManager/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-Shell-Core/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-Shell-Core/ActionCenter
    ignore_older: 24h
  - name: HardwareEvents
    ignore_older: 24h
    ignore_older: 24h
  - name: Microsoft-Windows-WMI-Activity/Operational
    #event_id: 5857,5858,5859,5860,5861
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 5858
  - name: Microsoft-Windows-Kernel-WHEA/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-Kernel-WHEA/Errors
    ignore_older: 24h
  - name: Microsoft-Windows-Kernel-WDI/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-Kernel-StoreMgr/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-Kernel-ShimEngine/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-Kernel-Power/Thermal-Operational
    ignore_older: 24h
  - name: Microsoft-Windows-Kernel-PnP/Configuration
    ignore_older: 24h
  - name: Microsoft-Windows-Kernel-EventTracing/Admin
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 1569
          - equals.winlog.event_id: 1570
          - equals.winlog.event_id: 28
          - contains.message: 'Session "Diagtrack-Listener" stopped due to the following error:'
  - name: Microsoft-Windows-Kernel-Boot/Operational
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 158
  - name: Microsoft-Windows-WinRM/Operational
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 142
          - equals.winlog.event_id: 161
  - name: Microsoft-Windows-RemoteDesktopServices-RdpCoreTS/Operational
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 227
  - name: Microsoft-Windows-RemoteDesktopServices-RdpCoreTS/Admin
    ignore_older: 24h
  - name: Microsoft-Windows-Windows Firewall With Advanced Security/Firewall
    ignore_older: 24h
    include_xml: true
  - name: Microsoft-Windows-Windows Firewall With Advanced Security/ConnectionSecurity
    ignore_older: 24h
    include_xml: true
  - name: Microsoft-Windows-VPN/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-VPN-Client/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-TCPIP/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-GroupPolicy/Operational
    ignore_older: 24h
  # task scheduler: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Task-Scheduler.xml
  - name: Microsoft-Windows-TaskScheduler/Operational
    event_id: 106, 129, 141, 142, 200, 201
    ignore_older: 24h
    provider:
      - Microsoft-Windows-TaskScheduler
  - name: Security
    event_id: 4698-4702
    ignore_older: 24h
  - name: Microsoft-Windows-TaskScheduler/Maintenance
    ignore_older: 24h
  - name: Microsoft-Windows-StorageSpaces-ManagementAgent/WHC
    ignore_older: 24h
  - name: Microsoft-Windows-StorageSpaces-Driver/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-Storage-Tiering/Admin
    ignore_older: 24h
  - name: Microsoft-Windows-Storage-Storport/Operational
    level: "critical"
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 549
          - equals.winlog.event_id: 534
          - equals.winlog.event_id: 523
          - equals.winlog.event_id: 500
  - name: Microsoft-Windows-Storage-Storport/Admin
    ignore_older: 24h
  - name: Microsoft-Windows-SMBServer/Security
    ignore_older: 24h
  - name: Microsoft-Windows-SMBServer/Operational
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 1024
  - name: Microsoft-Windows-SMBServer/Connectivity
    ignore_older: 24h
  - name: Microsoft-Windows-SmbClient/Security
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 8464
          - equals.winlog.event_id: 31001
  - name: Microsoft-Windows-SMBClient/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-SmbClient/Connectivity
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 30800
          - equals.winlog.event_id: 30803
  - name: Key Management Service
    ignore_older: 24h
  - name: Internet Explorer
    ignore_older: 24h
  # dns: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/DNS.xml
  - name: Microsoft-Windows-DNS-Client/Operational
    event_id: 3008
    ignore_older: 24h
  - name: DNS Server
    event_id: 150, 770
    ignore_older: 24h
  - name: Microsoft-Windows-AppLocker/Packaged app-Execution
    ignore_older: 24h
  - name: Microsoft-Windows-AppLocker/Packaged app-Deployment
    ignore_older: 24h
  - name: Microsoft-Windows-AppLocker/MSI and Script
    ignore_older: 24h
  - name: Microsoft-Windows-AppLocker/EXE and DLL
    ignore_older: 24h
    level: "critical"
    ignore_older: 24h
    processors:
          - equals.winlog.event_id: 3033
  # Monitor USB Devices, this eventlog is not enabled by default
    event_id: 2003,2102
    ignore_older: 24h
  # Sysmon related, need some care soon. It IS VERY NOISY, we need a solic filter
    level: "critical, error, warning, information"
    # Minimum, for now!
    event_id: 255, 16, 14, 6
    ignore_older: 24h
  # NTFS
  - name: Microsoft-Windows-Ntfs/WHC
    ignore_older: 24h
  - name: Microsoft-Windows-Ntfs/Operational
    ignore_older: 24h
  # NTLM
  - name: Microsoft-Windows-NTLM/Operational
    ignore_older: 24h
  # General Remote Desktop and App related
  - name: Microsoft-Windows-Remotefs-Rdbss/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-RemoteDesktopServices-SessionServices/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-RemoteApp and Desktop Connections/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-RemoteApp and Desktop Connections/Admin
    ignore_older: 24h
  # DeviceSync
  - name: Microsoft-Windows-DeviceSync/Operational
    ignore_older: 24h
  # TerminalServices
  - name: Microsoft-Windows-TerminalServices-ServerUSBDevices/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-TerminalServices-ServerUSBDevices/Admin
    ignore_older: 24h
    ignore_older: 24h
    ignore_older: 24h
  - name: Microsoft-Windows-TerminalServices-RDPClient/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-TerminalServices-Printers/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-TerminalServices-Printers/Admin
    ignore_older: 24h
  - name: Microsoft-Windows-TerminalServices-PnPDevices/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-TerminalServices-PnPDevices/Admin
    ignore_older: 24h
    ignore_older: 24h
    ignore_older: 24h
  - name: Microsoft-Windows-TerminalServices-ClientUSBDevices/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-TerminalServices-ClientUSBDevices/Admin
    ignore_older: 24h
  - name: Microsoft-Windows-TerminalServices-Gateway/Admin
    ignore_older: 24h
  - name: Microsoft-Windows-TerminalServices-Gateway/Operational
    ignore_older: 24h
  - name: Microsoft-Windows-Winlogon/Operational
    ignore_older: 24h
  #windows update: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Windows-Updates.xml
  - name: Microsoft-Windows-WindowsUpdateClient/Operational
    event_id: 19, 20, 24, 25, 31, 34, 35
    ignore_older: 24h
    level: error
    provider:
      - Microsoft-Windows-WindowsUpdateClient
  - name: Setup
    event_id: 1009
    ignore_older: 24h
    level: info
    provider:
      - Microsoft-Windows-Servicing
  # external devices: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/External-Devices.xml
    event_id: 400, 410
    ignore_older: 24h
    level: info
    provider:
  - name: Security
    event_id: 6416
    ignore_older: 24h
  - name: Security
    event_id: 6419-6424
    ignore_older: 24h
  # firewall: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Firewall.xml
    event_id: 2004, 2005, 2006, 2033
    ignore_older: 24h
    level: info, error
    provider:
      - Microsoft-Windows-Windows Firewall With Advanced Security
  - name: Security
    event_id: 4944-4954
    ignore_older: 24h
  - name: Security
    event_id: 4956-4958
    ignore_older: 24h
  - name: Security
    event_id: 5024, 5025, 5037
    ignore_older: 24h
  - name: Security
    event_id: 5027-5030
    ignore_older: 24h
  - name: Security
    event_id: 5032-5035
    ignore_older: 24h
  # gpo errors: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Group-Policy-Errors.xml
  - name: System
    event_id: 1085, 1125, 1127, 1129
    ignore_older: 24h
    level: error
    provider:
      - Microsoft-Windows-GroupPolicy
  - name: Security
    event_id: 6144, 6145
    ignore_older: 24h
  # kerberos: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Kerberos.xml
  - name: Security
    event_id: 4768, 4769, 4770, 4771, 4772, 4773
    ignore_older: 24h
  # log deletion security: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Log-Deletion-Security.xml
  - name: Security
    event_id: 1102
    ignore_older: 24h
    level: info
    provider:
  # log deletion system: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Log-Deletion-System.xml
  - name: System
    event_id: 104
    ignore_older: 24h
    level: info
    provider:
  # msi: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/MSI-Packages.xml
  - name: Application
    event_id: 1022, 1033
    ignore_older: 24h
    provider:
      - MsiInstaller
  - name: Setup
    event_id: 2, 0
    ignore_older: 24h
    provider:
  - name: Microsoft-Windows-Application-Experience/Program-Inventory
    event_id: 903, 904
    ignore_older: 24h
    provider:
      - Microsoft-Windows-Application-Experience
    event_id: 905, 906
    ignore_older: 24h
    provider:
    event_id: 907, 908
    ignore_older: 24h
    provider:
    event_id: 800
    ignore_older: 24h
    provider:
  # ntml: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/NTLM.xml
  - name: Microsoft-Windows-Authentication/AuthenticationPolicyFailures-DomainController
    ignore_older: 24h
    provider:
      - Microsoft-Windows-NTLM
  - name: Microsoft-Windows-Authentication/ProtectedUserFailures-DomainController
    ignore_older: 24h
    provider:
    ignore_older: 24h
    provider:
  # object manipulation: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Object-Manipulation.xml
  - name: Security
    event_id: 4715, 4817, 4656, 4658, 4660, 4663, 4670
    ignore_older: 24h
  # operating system: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Operating-System.xml
  - name: System
    event_id: 12, 13
    ignore_older: 24h
    provider:
      - Microsoft-Windows-Kernel-General
  - name: Security
    event_id: 4608
    ignore_older: 24h
  - name: System
    event_id: 1074
    ignore_older: 24h
    provider:
      - USER32
  - name: Security
    event_id: 4817, 4826
    ignore_older: 24h
  - name: System
    event_id: 16962, 16965, 16968, 16969
    ignore_older: 24h
  - name: System
    event_id: 41, 1001, 6008, 4621
    ignore_older: 24h
  - name: Security
    event_id: 4610, 4611, 4614, 4622, 4697
    ignore_older: 24h
  - name: Security
    event_id: 4719, 4817, 4902, 4906, 4908, 4912, 4904, 4905
    ignore_older: 24h
  # print: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Print.xml
  - name: Microsoft-Windows-PrintService/Operational
    event_id: 307
    ignore_older: 24h
    level: info
    provider:
      - Microsoft-Windows-PrintService
  # privilege use: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Privilege-Use.xml
  - name: Security
    event_id: 4673, 4674, 4985
    ignore_older: 24h
  # process exec: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Process-Execution.xml
  #- name: Security
  #  event_id: 4688
  #  ignore_older: 24h
  - name: Security
    event_id: 4689
    ignore_older: 24h
  # registry: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Registry.xml
  # TODO: how to filter on eventdata operationtype?
  - name: Security
    event_id: 4657
    ignore_older: 24h
  # services: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Services.xml
  - name: System
    event_id: 7022, 7023, 7024, 7026, 7031, 7032, 7034
    ignore_older: 24h
    level: info, critical, error, warning
    provider:
      - Service Control Manager
  - name: System
    event_id: 7045, 7040
    ignore_older: 24h
    provider:
  # shares: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Shares.xml
  - name: Security
    event_id: 5140, 5142, 5144, 5145, 5168
    ignore_older: 24h
    event_id: 30622, 30624
    ignore_older: 24h
  # software restrictions: https://github.com/palantir/windows-event-forwarding/blob/master/wef-subscriptions/Software-Restriction-Policies.xml
  - name: Application
    event_id: 865, 866, 867, 868, 882
    ignore_older: 24h
    provider:
      - Microsoft-Windows-SoftwareRestrictionPolicies
# Add JS Infos
processors:
  - script:
      lang: javascript
  - script:
      lang: javascript
  - script:
      lang: javascript
  - script:
      lang: javascript
  - script:
      lang: javascript
  - script:
      when.equals.winlog.channel: Microsoft-Windows-PowerShell/Admin
      lang: javascript
  - script:
      lang: javascript
  - script:
      when.equals.winlog.channel: Microsoft-Windows-Shell-Core
      lang: javascript
  - script:
      when.equals.winlog.channel: PowerShellCore/Operational
      lang: javascript
  - script:
      lang: javascript
But I am wanting to do a configuration from scratch to drop events not only from users but also from executables that appear in the logs.
I think you are only running into some syntax issues in your configuration. The logs to a good job telling you if it has an issue with the Collector configuration (in your original post, you have sidecar logs at: C:\Program Files\Graylog\sidecar\logs)
Here are some rearranged syntax… I haven’t tested them yet… maybe later today… but they fit a little better with what I have had working in the past. Most specifically, I think the fields need the winlog. in front of them… at least that worked for me. (Noting that in my Graylog it shows as winlog_ but the beat wants winlog.)
    - name: Security
      processors:
        - drop_event.when:
            contains:
              winlog.event_data_TargetUserName: sauser
in this second case you have above, you had when in there twice… not sure that would work…
    - name: Security
      processors:
        - drop_event.when:
          - or:
              - equals.winlog.event_data_ProcessName: C:\Program Files\Graylog\sidecar\graylog-sidecar.exe
              - equals.winlog.event_data_TargetUserName: user1
              - equals.winlog.event_data_TargetUserName: user2
              - equals.winlog.event_data_SubjectUserName: user2
@tmacgbay Thanks for your support.
I am taking the necessary care with the YAML formatting. I am doing the edits using Visual Code.
I tried to do as posted above, but I keep getting logs from a specific user. Both sidecar.log and winlogbeat.log showed no errors.
sidecar.log:
time="2022-03-25T11:45:03-03:00" level=info msg="[winlogbeat] Configuration change detected, rewriting configuration file."
time="2022-03-25T11:45:03-03:00" level=info msg="[winlogbeat] Stopping"
time="2022-03-25T11:45:04-03:00" level=info msg="[winlogbeat] Starting (svc driver)"
winlogbeat:
2022-03-25T11:45:05.025-0300	INFO	instance/beat.go:686	Home path: [C:\Program Files\Graylog\sidecar] Config path: [C:\Program Files\Graylog\sidecar] Data path: [C:\Program Files\Graylog\sidecar\cache\winlogbeat\data] Logs path: [C:\Program Files\Graylog\sidecar\logs] Hostfs Path: [/]
2022-03-25T11:45:05.028-0300	INFO	instance/beat.go:694	Beat ID: 2463d591-5825-4e79-8465-1350a716c9e3
2022-03-25T11:45:05.029-0300	INFO	[beat]	instance/beat.go:1040	Beat info	{"system_info": {"beat": {"path": {"config": "C:\\Program Files\\Graylog\\sidecar", "data": "C:\\Program Files\\Graylog\\sidecar\\cache\\winlogbeat\\data", "home": "C:\\Program Files\\Graylog\\sidecar", "logs": "C:\\Program Files\\Graylog\\sidecar\\logs"}, "type": "winlogbeat", "uuid": "2463d591-5825-4e79-8465-1350a716c9e3"}}}
2022-03-25T11:45:05.029-0300	INFO	[beat]	instance/beat.go:1049	Build info	{"system_info": {"build": {"commit": "1d05ba86138cfc9a5ae5c0acc64a57b8d81678ff", "libbeat": "7.17.1", "time": "2022-02-23T23:58:09.000Z", "version": "7.17.1"}}}
2022-03-25T11:45:05.029-0300	INFO	[beat]	instance/beat.go:1052	Go runtime info	{"system_info": {"go": {"os":"windows","arch":"amd64","max_procs":2,"version":"go1.17.6"}}}
2022-03-25T11:45:05.033-0300	INFO	[beat]	instance/beat.go:1056	Host info	{"system_info": {"host": {"architecture":"x86_64","boot_time":"2022-03-22T13:38:53.87-03:00","name":"DC01","ip":["10.0.0.12/24","::1/128","127.0.0.1/8","fe80::5efe:a00:c/128"],"kernel_version":"6.3.9600.16422 (winblue_gdr.131006-1505)","mac":["00:00:00:00:00:00","00:00:00:00:00:00:00:e0"],"os":{"type":"windows","family":"windows","platform":"windows","name":"Windows Server 2012 R2 Standard","version":"6.3","major":3,"minor":0,"patch":0,"build":"9600.0"},"timezone":"-03","timezone_offset_sec":-10800,"id":"e7ff1b2c-d7d3-4a35-9ae0-a840abc75646"}}}
2022-03-25T11:45:05.033-0300	INFO	[beat]	instance/beat.go:1085	Process info	{"system_info": {"process": {"cwd": "C:\\Windows\\system32", "exe": "C:\\Program Files\\Graylog\\sidecar\\winlogbeat.exe", "name": "winlogbeat.exe", "pid": 5604, "ppid": 504, "start_time": "2022-03-25T11:45:04.906-0300"}}}
2022-03-25T11:45:05.033-0300	INFO	instance/beat.go:328	Setup Beat: winlogbeat; Version: 7.17.1
2022-03-25T11:45:05.033-0300	INFO	[publisher]	pipeline/module.go:113	Beat name: DC01
2022-03-25T11:45:05.033-0300	INFO	[winlogbeat]	beater/winlogbeat.go:66	State will be read from and persisted to C:\Program Files\Graylog\sidecar\cache\winlogbeat\data\.winlogbeat.yml
2022-03-25T11:45:05.034-0300	INFO	instance/beat.go:492	winlogbeat start running.
2022-03-25T11:45:05.034-0300	INFO	[monitoring]	log/log.go:142	Starting metrics logging every 30s
2022-03-25T11:45:06.056-0300	INFO	[publisher_pipeline_output]	pipeline/output.go:143	Connecting to backoff(async(tcp://10.0.0.53:5044))
2022-03-25T11:45:06.056-0300	INFO	[publisher]	pipeline/retry.go:219	retryer: send unwait signal to consumer
2022-03-25T11:45:06.056-0300	INFO	[publisher]	pipeline/retry.go:223	  done
2022-03-25T11:45:06.060-0300	INFO	[publisher_pipeline_output]	pipeline/output.go:151	Connection to backoff(async(tcp://10.0.0.53:5044)) established
2022-03-25T11:45:35.046-0300	INFO	[monitoring]	log/log.go:184	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":171,"time":{"ms":171}},"total":{"ticks":499,"time":{"ms":499},"value":499},"user":{"ticks":328,"time":{"ms":328}}},"handles":{"open":205},"info":{"ephemeral_id":"5e04e733-e9ba-43f0-b94a-c6a78c2d5599","uptime":{"ms":30097},"version":"7.17.1"},"memstats":{"gc_next":11496256,"memory_alloc":6053216,"memory_sys":27429896,"memory_total":53753952,"rss":43646976},"runtime":{"goroutines":52}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":312,"active":0,"batches":19,"total":312},"read":{"bytes":114},"type":"logstash","write":{"bytes":95382}},"pipeline":{"clients":11,"events":{"active":8,"published":320,"retry":12,"total":320},"queue":{"acked":312,"max_events":4096}}},"system":{"cpu":{"cores":2}}}}}
2022-03-25T11:46:05.046-0300	INFO	[monitoring]	log/log.go:184	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":218,"time":{"ms":47}},"total":{"ticks":905,"time":{"ms":406},"value":905},"user":{"ticks":687,"time":{"ms":359}}},"handles":{"open":209},"info":{"ephemeral_id":"5e04e733-e9ba-43f0-b94a-c6a78c2d5599","uptime":{"ms":60097},"version":"7.17.1"},"memstats":{"gc_next":13199408,"memory_alloc":11951456,"memory_total":91708384,"rss":42913792},"runtime":{"goroutines":52}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":250,"active":0,"batches":19,"total":250},"read":{"bytes":114},"write":{"bytes":91633}},"pipeline":{"clients":11,"events":{"active":37,"published":279,"total":279},"queue":{"acked":250}}}}}}
2022-03-25T11:46:35.043-0300	INFO	[monitoring]	log/log.go:184	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":359,"time":{"ms":141}},"total":{"ticks":1374,"time":{"ms":469},"value":1374},"user":{"ticks":1015,"time":{"ms":328}}},"handles":{"open":209},"info":{"ephemeral_id":"5e04e733-e9ba-43f0-b94a-c6a78c2d5599","uptime":{"ms":90086},"version":"7.17.1"},"memstats":{"gc_next":12572544,"memory_alloc":6425528,"memory_total":128752264,"rss":43409408},"runtime":{"goroutines":52}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":229,"active":0,"batches":22,"total":229},"read":{"bytes":132},"write":{"bytes":91686}},"pipeline":{"clients":11,"events":{"active":8,"published":200,"total":200},"queue":{"acked":229}}}}}}
2022-03-25T11:47:05.043-0300	INFO	[monitoring]	log/log.go:184	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":468,"time":{"ms":109}},"total":{"ticks":1780,"time":{"ms":406},"value":1780},"user":{"ticks":1312,"time":{"ms":297}}},"handles":{"open":211},"info":{"ephemeral_id":"5e04e733-e9ba-43f0-b94a-c6a78c2d5599","uptime":{"ms":120086},"version":"7.17.1"},"memstats":{"gc_next":15376672,"memory_alloc":9254384,"memory_total":168663048,"rss":44142592},"runtime":{"goroutines":52}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":321,"active":0,"batches":20,"total":321},"read":{"bytes":120},"write":{"bytes":105578}},"pipeline":{"clients":11,"events":{"active":0,"published":313,"total":313},"queue":{"acked":321}}}}}}
2022-03-25T11:47:35.042-0300	INFO	[monitoring]	log/log.go:184	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":593,"time":{"ms":125}},"total":{"ticks":2139,"time":{"ms":359},"value":2139},"user":{"ticks":1546,"time":{"ms":234}}},"handles":{"open":211},"info":{"ephemeral_id":"5e04e733-e9ba-43f0-b94a-c6a78c2d5599","uptime":{"ms":150086},"version":"7.17.1"},"memstats":{"gc_next":13201744,"memory_alloc":10772184,"memory_total":206358192,"rss":44777472},"runtime":{"goroutines":52}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":248,"active":0,"batches":20,"total":248},"read":{"bytes":120},"write":{"bytes":95614}},"pipeline":{"clients":11,"events":{"active":12,"published":260,"total":260},"queue":{"acked":248}}}}}}
2022-03-25T11:48:05.041-0300	INFO	[monitoring]	log/log.go:184	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":671,"time":{"ms":78}},"total":{"ticks":2405,"time":{"ms":266},"value":2405},"user":{"ticks":1734,"time":{"ms":188}}},"handles":{"open":206},"info":{"ephemeral_id":"5e04e733-e9ba-43f0-b94a-c6a78c2d5599","uptime":{"ms":180086},"version":"7.17.1"},"memstats":{"gc_next":11746784,"memory_alloc":7172288,"memory_total":238241208,"rss":42418176},"runtime":{"goroutines":52}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":139,"active":0,"batches":20,"total":139},"read":{"bytes":120},"write":{"bytes":67600}},"pipeline":{"clients":11,"events":{"active":0,"published":127,"total":127},"queue":{"acked":139}}}}}}
2022-03-25T11:48:35.044-0300	INFO	[monitoring]	log/log.go:184	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":796,"time":{"ms":125}},"total":{"ticks":2874,"time":{"ms":469},"value":2874},"user":{"ticks":2078,"time":{"ms":344}}},"handles":{"open":211},"info":{"ephemeral_id":"5e04e733-e9ba-43f0-b94a-c6a78c2d5599","uptime":{"ms":210086},"version":"7.17.1"},"memstats":{"gc_next":11782976,"memory_alloc":7572224,"memory_total":278319800,"rss":42573824},"runtime":{"goroutines":52}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":252,"active":0,"batches":21,"total":252},"read":{"bytes":126},"write":{"bytes":102593}},"pipeline":{"clients":11,"events":{"active":8,"published":260,"total":260},"queue":{"acked":252}}}}}}
2022-03-25T11:49:05.042-0300	INFO	[monitoring]	log/log.go:184	Non-zero metrics in the last 30s	{"monitoring": {"metrics": {"beat":{"cpu":{"system":{"ticks":906,"time":{"ms":110}},"total":{"ticks":3343,"time":{"ms":469},"value":3343},"user":{"ticks":2437,"time":{"ms":359}}},"handles":{"open":211},"info":{"ephemeral_id":"5e04e733-e9ba-43f0-b94a-c6a78c2d5599","uptime":{"ms":240087},"version":"7.17.1"},"memstats":{"gc_next":12459520,"memory_alloc":8499536,"memory_total":320516800,"rss":44085248},"runtime":{"goroutines":52}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":374,"active":0,"batches":20,"total":374},"read":{"bytes":120},"write":{"bytes":116320}},"pipeline":{"clients":11,"events":{"active":2,"published":368,"total":368},"queue":{"acked":374}}}}}}
One other fact, I am using winlogbeat version 7.17.1. Could there be a problem with this version?
not that I know of - did you add in the winlog portion with the dot to the field name?
Yes, it complies with winlogbeat 7.17 standards:
    - name: Security
      processors:
        - drop_event.when:
            contains:
I finally got a chance to do some testing since I wanted to drop some of the junk coming into my system…
Try putting a dot between data and TargetUserName
     - name: Security
      processors:
        - drop_event.when:
            contains:
              winlog.event_data.TargetUserName: user1
Graylog is converting the . to _
bingo @tmacgbay
It was precisely “_” that had no effect and no error. After changing to the “.”, the filtering was done.
Here is the tested configuration:
output.logstash:
path:
tags:
  - windows
winlogbeat:
  event_logs:
    - name: Application
    - name: System
    - name: Security
      processors:
        - drop_event.when:
            or:
              - contains:
              - contains:
                  winlog.event_data.TargetUserName: user2
              - contains:
                  winlog.event_data.SubjectUserName: user2
    - name: DNS Server
thank you very much @tmacgbay
My thanks also to @gsmith . Your information about SID was valuable and I already plan to apply.
I have one more problem, I am having trouble with drop events related to .exe.
Here is a message that I want to block:
message
Houve uma tentativa de acessar um objeto.
Requerente:
	Id de Segurança:		S-1-5-18
	Nome da Conta:		SRV001$
	Domínio da Conta:		MYDOMAIN
	ID de Logon:		0x3E7
Objeto:
	Servidor do Objeto:		Security
	Tipo de Objeto:		File
	Nome do Objeto:		E:\
	ID do Identificador:		0x29c
	Atributos do Recurso:	S:PAI
Informações do Processo:
	ID do Processo:		0x2080
	Nome do Processo:		C:\Program Files\Graylog\sidecar\graylog-sidecar.exe
Informações da Solicitação de Acesso:
	Acessos:		ReadData (ou ListDirectory)
	Máscara de Acesso:	0x1
Config used to try to drop:
output.logstash:
path:
tags:
  - windows
winlogbeat:
  event_logs:
    - name: Application
    - name: System
    - name: Security
      processors:
        - drop_event.when:
            or:
              - contains:
                  winlog.event_data.TargetUserName: usr1
              - contains:
                  winlog.event_data.TargetUserName: usr2
              - contains:
                  winlog.event_data.SubjectUserName: usr1
              - contains:
                  winlog.event_data.ProcessName: C:\Program Files\Graylog\sidecar\graylog-sidecar.exe
              - contains:
                  winlog.event_data.ProcessId: "0x114c"
    - name: DNS Server
to make sure they are string values, elasticsearch has quotes around the values… you could possibly use a regex solution such as:
- regexp:
      winlog.event_data.ProcessName: "sidecar\.exe$"  # Anything that ends ($) with sidecar.exe
You may need to use the debug() function to find out what the actual field is…
Problem solved. To block events coming from “winlog.event_data.ProcessName”, I put the complete path with exe, but with two backslashes. Ex:
output.logstash:
path:
tags:
  - windows
winlogbeat:
  event_logs:
    - name: Application
    - name: System
    - name: Security
      processors:
        - drop_event.when:
            or:
              - contains:
                  winlog.event_data.ProcessName: "C:\\Program Files\\Graylog\\sidecar\\graylog-sidecar.exe"
    - name: DNS Server
@maiconjs
Nice and thank for sharing your resolve with us. I’ve been watch this post to see how your executing this issue. This is good stuff :+1: If you could mark this as resolved for future searches that would be great :smiley:
