Drop debug logs with pipeline
My 6 ESXi hypervisors floods graylog with 2M messages a day, majority of logs are DEBUG (~90%), so I want to drop DEBUG logs entirely.
SETUP
I have separate input just for ESXi: syslog on 1514/tcp.
I created “ESXi” stream which takes logs just from that input: Field gl2_source_input must match exactly 5XXXXXXXXXXX
Pipeline rule:
rule “dropOnDebug”
to_string($message.level) == “7”
drop_message();
Pipeline connections: stream “ESXi”
Stage0: dropOnDebug (At least one of the rules on this stage matches the message)
I still get DEBUG logs.
  • what is your processing order in System > configuration?
    • place processing pipeline after message filter chain
  • does your messages have the field level and that contains a number?
Placing “Pipeline Processor” after “Message Filter Chain” in System > configuration solved the problem.
Does drop_message() function in pipeline deletes message from disk?
To be exact this prevents the messages from being stored into Elasticsearch because they are dropped before they are ingested to it.
