Dear @gsmith,
I thought, if I create the networks via docker, all the needed routing is done by docker, isn’t it?
I did some more testing, this is my current state:
- Ubuntu Server (HP EliteDesk 800 G2) is on 192.168.70.2 - IP provided via DHCP - accessible via ssh
- HomeAssistant is on 192.168.30.20 - IP based on macvlan30 - accessible via web GUI
- Graylog is on 192.168.70.3 - IP based on macvlan70 - not accessible via GUI, no ping from Asus-laptop possible.
Any idea, how I can make Graylog accessible again?
some more info
uadmin@ubuntu:~$ ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether fc:3f:db:07:69:e5 brd ff:ff:ff:ff:ff:ff
altname enp0s31f6
inet 192.168.70.2/25 metric 100 brd 192.168.70.127 scope global dynamic eno1
valid_lft 85046sec preferred_lft 85046sec
inet6 fe80::fe3f:dbff:fe07:69e5/64 scope link
3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:19:e8:1c:24 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
4: br-a8ed596cd6d7: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
link/ether 02:42:ed:11:77:13 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/24 brd 10.10.10.255 scope global br-a8ed596cd6d7
inet6 fe80::42:edff:fe11:7713/64 scope link
5: eno1.70@eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
6: eno1.30@eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
8: vethec8b94d@if7: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-a8ed596cd6d7 state UP group default
link/ether f2:38:a9:31:6d:bb brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::f038:a9ff:fe31:6dbb/64 scope link
11: vethe028d4a@if10: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-a8ed596cd6d7 state UP group default
link/ether 22:18:8f:c0:f7:b3 brd ff:ff:ff:ff:ff:ff link-netnsid 3
inet6 fe80::2018:8fff:fec0:f7b3/64 scope link
13: veth9e0bd48@if12: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-a8ed596cd6d7 state UP group default
link/ether 7a:c6:ce:56:66:9f brd ff:ff:ff:ff:ff:ff link-netnsid 1
inet6 fe80::78c6:ceff:fe56:669f/64 scope link
uadmin@ubuntu:~$ docker network ls
NETWORK ID NAME DRIVER SCOPE
628aaf5ad141 bridge bridge local
a8ed596cd6d7 graylog_graylog_backend bridge local
989a7cc8de67 host host local
96834b94c746 macvlan30 macvlan local
4663a4b40f99 macvlan70 macvlan local
fb9e3c4b2724 none null local
Unifi client devices
The docker container just went offline in my Unifi environment, but if I inspect the container, it is still there, healhy and running.
uadmin@ubuntu:~$ docker container inspect graylog-graylog-1
"Id": "5ce7fed1ccb8cfb770337da8d0b66c0627e58e73eb295b9f2372deb51cebd17a",
"Created": "2022-12-23T23:12:33.678519391Z",
"Path": "/usr/bin/tini",
"Args": [
"wait-for-it",
"elasticsearch:9200",
"/docker-entrypoint.sh"
"State": {
"Status": "running",
"Running": true,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 1223,
"ExitCode": 0,
"Error": "",
"StartedAt": "2022-12-25T15:29:16.577137314Z",
"FinishedAt": "2022-12-25T15:28:35.425159405Z",
"Health": {
"Status": "healthy",
"FailingStreak": 0,
"Log": [
"Start": "2022-12-25T17:02:56.30703134+01:00",
"End": "2022-12-25T17:02:56.438637326+01:00",
"ExitCode": 0,
"Output": "{\"cluster_id\":\"d1055499-7afa-4e63-883d-191dfd68ac27\",\"node_id\":\"e3923345-1eb2-43a2-8339-c60bf94e7539\",\"version\":\"5.0.1+f28b729\",\"tagline\":\"Manage your logs in the dark and have lasers going and make it look like you're from space!\"}"
"Start": "2022-12-25T17:03:06.455849725+01:00",
"End": "2022-12-25T17:03:06.594247158+01:00",
"ExitCode": 0,
"Start": "2022-12-25T17:03:16.608613815+01:00",
"End": "2022-12-25T17:03:16.743843181+01:00",
"ExitCode": 0,
"Start": "2022-12-25T17:03:26.760143886+01:00",
"End": "2022-12-25T17:03:26.894179526+01:00",
"ExitCode": 0,
"Start": "2022-12-25T17:03:36.909386108+01:00",
"End": "2022-12-25T17:03:37.022068941+01:00",
"ExitCode": 0,
"Image": "sha256:a2705548029a105aa0a5fe79a6e9c3d92d4a624b519d0f5ab67862a68138423c",
"ResolvConfPath": "/var/lib/docker/containers/5ce7fed1ccb8cfb770337da8d0b66c0627e58e73eb295b9f2372deb51cebd17a/resolv.conf",
"HostnamePath": "/var/lib/docker/containers/5ce7fed1ccb8cfb770337da8d0b66c0627e58e73eb295b9f2372deb51cebd17a/hostname",
"HostsPath": "/var/lib/docker/containers/5ce7fed1ccb8cfb770337da8d0b66c0627e58e73eb295b9f2372deb51cebd17a/hosts",
"LogPath": "/var/lib/docker/containers/5ce7fed1ccb8cfb770337da8d0b66c0627e58e73eb295b9f2372deb51cebd17a/5ce7fed1ccb8cfb770337da8d0b66c0627e58e73eb295b9f2372deb51cebd17a-json.log",
"Name": "/graylog-graylog-1",
"RestartCount": 0,
"Driver": "overlay2",
"Platform": "linux",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "docker-default",
"ExecIDs": null,
"HostConfig": {
"Binds": [],
"ContainerIDFile": "",
"LogConfig": {
"Type": "json-file",
"Config": {}
"NetworkMode": "macvlan70",
"PortBindings": {
"12201/": [
"HostIp": "0.0.0.0",
"HostPort": "12201"
"1514/": [
"HostPort": "1514"
"9000/": [
"HostPort": "9000"
"RestartPolicy": {
"Name": "unless-stopped",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": null,
"CapAdd": null,
"CapDrop": null,
"CgroupnsMode": "private",
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": [],
"GroupAdd": null,
"IpcMode": "private",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyRootfs": false,
"SecurityOpt": null,
"UTSMode": "",
"UsernsMode": "",
"ShmSize": 67108864,
"Runtime": "runc",
"ConsoleSize": [
0,
0
"Isolation": "",
"CpuShares": 0,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "",
"BlkioWeight": 0,
"BlkioWeightDevice": null,
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": null,
"DeviceCgroupRules": null,
"DeviceRequests": null,
"KernelMemory": 0,
"KernelMemoryTCP": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"OomKillDisable": null,
"PidsLimit": null,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0,
"Mounts": [
"Type": "volume",
"Source": "368e86bfb2209e3c04a3bf1137dd98b6c06293e652cff2ef9670c840d3a705be",
"Target": "/usr/share/graylog/data"
"Type": "volume",
"Source": "graylog_graylog_journal",
"Target": "/usr/share/graylog/data/journal"
"MaskedPaths": [
"/proc/asound",
"/proc/acpi",
"/proc/kcore",
"/proc/keys",
"/proc/latency_stats",
"/proc/timer_list",
"/proc/timer_stats",
"/proc/sched_debug",
"/proc/scsi",
"/sys/firmware"
"ReadonlyPaths": [
"/proc/bus",
"/proc/fs",
"/proc/irq",
"/proc/sys",
"/proc/sysrq-trigger"
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/f3a3a4955e31fad30cf273b1d3668f79a6fa2e9ea94d0d22cf2dee7f9a42d49c-init/diff:/var/lib/docker/overlay2/f27f6ad61fe72b6be4f6d5223bb5048ff81c6d1a422e1a8696ab90021d0ad487/diff:/var/lib/docker/overlay2/4615c550dfa661ddf40130f0961c76931444e016a13bdd7f49a2e39aad0ba8fa/diff:/var/lib/docker/overlay2/adecbf556df26c1eba0cf49c964cf7449229d9a049504dcf9d87bdcdc5f08e82/diff:/var/lib/docker/overlay2/253967d726a16b6c1fbe457efeec2d64263004df7655d9e8e1c8084c3ec4a3e4/diff:/var/lib/docker/overlay2/0953c46a993fa25a52b2ecedfc267e63011e17074ca713e05ff74da0a2e2a62a/diff:/var/lib/docker/overlay2/71e63935ad88f2319a3fae3ddc343594478cbe4b7fc1f8a71ffa33d8ea83e9b1/diff:/var/lib/docker/overlay2/8775c2724ae112034133247712972d3b41c226d68b265503383c26b68dff5567/diff:/var/lib/docker/overlay2/40aa18738583838a0223bd4addb86a8e66800bbd1dd517116930c96b0b5adb25/diff:/var/lib/docker/overlay2/767af6d51eeac5c67d8b3f33b16064ab2e00e553d6ad73ea120564d69b85ba98/diff",
"MergedDir": "/var/lib/docker/overlay2/f3a3a4955e31fad30cf273b1d3668f79a6fa2e9ea94d0d22cf2dee7f9a42d49c/merged",
"UpperDir": "/var/lib/docker/overlay2/f3a3a4955e31fad30cf273b1d3668f79a6fa2e9ea94d0d22cf2dee7f9a42d49c/diff",
"WorkDir": "/var/lib/docker/overlay2/f3a3a4955e31fad30cf273b1d3668f79a6fa2e9ea94d0d22cf2dee7f9a42d49c/work"
"Name": "overlay2"
"Mounts": [
"Type": "volume",
"Name": "graylog_graylog_journal",
"Source": "/var/lib/docker/volumes/graylog_graylog_journal/_data",
"Destination": "/usr/share/graylog/data/journal",
"Driver": "local",
"Mode": "z",
"RW": true,
"Propagation": ""
"Type": "volume",
"Name": "368e86bfb2209e3c04a3bf1137dd98b6c06293e652cff2ef9670c840d3a705be",
"Source": "/var/lib/docker/volumes/368e86bfb2209e3c04a3bf1137dd98b6c06293e652cff2ef9670c840d3a705be/_data",
"Destination": "/usr/share/graylog/data",
"Driver": "local",
"Mode": "z",
"RW": true,
"Propagation": ""
"Config": {
"Hostname": "5ce7fed1ccb8",
"Domainname": "",
"User": "graylog",
"AttachStdin": false,
"AttachStdout": true,
"AttachStderr": true,
"ExposedPorts": {
"12201/": {},
"1514/": {},
"9000/": {},
"9000/tcp": {}
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"GRAYLOG_PASSWORD_SECRET=[abcd]",
"GRAYLOG_ROOT_PASSWORD_SHA2=[efgh]",
"GRAYLOG_HTTP_EXTERNAL_URI=http://192.168.70.3:9000/",
"GRAYLOG_HTTP_ENABLE_CORS=true",
"PATH=/opt/java/openjdk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"JAVA_HOME=/opt/java/openjdk",
"LANG=en_US.UTF-8",
"LANGUAGE=en_US:en",
"LC_ALL=en_US.UTF-8",
"JAVA_VERSION=jdk-17.0.5+8"
"Cmd": null,
"Healthcheck": {
"Test": [
"CMD-SHELL",
"/health_check.sh"
"Interval": 10000000000,
"Timeout": 2000000000,
"Retries": 12
"Image": "graylog/graylog:5.0",
"Volumes": {
"/usr/share/graylog/data": {},
"/usr/share/graylog/data/journal": {}
"WorkingDir": "/usr/share/graylog",
"Entrypoint": [
"/usr/bin/tini",
"wait-for-it",
"OnBuild": null,
"Labels": {
"com.docker.compose.config-hash": "ccb1d575c41352be5745fe0611afbcfb47bee2953159ae4d17aad6b6ac380c26",
"com.docker.compose.container-number": "1",
"com.docker.compose.depends_on": "mongodb:service_started,elasticsearch:service_started",
"com.docker.compose.image": "sha256:a2705548029a105aa0a5fe79a6e9c3d92d4a624b519d0f5ab67862a68138423c",
"com.docker.compose.oneoff": "False",
"com.docker.compose.project": "graylog",
"com.docker.compose.project.config_files": "/home/uadmin/Docker/Graylog/compose.yaml",
"com.docker.compose.project.working_dir": "/home/uadmin/Docker/Graylog",
"com.docker.compose.service": "graylog",
"com.docker.compose.version": "2.14.1",
"maintainer": "Graylog, Inc. <hello@graylog.com>",
"org.label-schema.build-date": "2022-12-14T15:57:38Z",
"org.label-schema.description": "Official Graylog Docker image",
"org.label-schema.name": "Graylog Docker Image",
"org.label-schema.schema-version": "1.0",
"org.label-schema.url": "https://www.graylog.org/",
"org.label-schema.vcs-ref": "",
"org.label-schema.vcs-url": "https://github.com/Graylog2/graylog-docker",
"org.label-schema.vendor": "Graylog, Inc.",
"org.label-schema.version": "5.0.1"
"NetworkSettings": {
"Bridge": "",
"SandboxID": "44a74b851c8298b69b36a19f31c327445a0e13639c383879512f697240731e3f",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {},
"SandboxKey": "/var/run/docker/netns/44a74b851c82",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "",
"Gateway": "",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"Networks": {
"graylog_graylog_backend": {
"IPAMConfig": {
"IPv4Address": "10.10.10.2"
"Links": [
"graylog-mongodb-1:mongo",
"graylog-mongodb-1:mongodb-1",
"graylog-mongodb-1:graylog-mongodb-1",
"graylog-elasticsearch-1:elasticsearch",
"graylog-elasticsearch-1:elasticsearch-1",
"graylog-elasticsearch-1:graylog-elasticsearch-1"
"Aliases": [
"graylog-graylog-1",
"graylog",
"5ce7fed1ccb8"
"NetworkID": "a8ed596cd6d7427f869458366dab0168f2682f091e762a3e4163b8b1b4303ae4",
"EndpointID": "15dd4975a40f76e1324d8d9d8ba4dd55aba191080fdd6d83403b37ba722ed365",
"Gateway": "10.10.10.1",
"IPAddress": "10.10.10.2",
"IPPrefixLen": 24,
"IPv6Gateway": "",
"MacAddress": "02:42:0a:0a:0a:02",
"DriverOpts": null
"macvlan70": {
"IPAMConfig": {
"IPv4Address": "192.168.70.3"
"Links": [
"Aliases": [
"graylog",
"5ce7fed1ccb8"
"NetworkID": "4663a4b40f994de81c1b9a55312163270d1cf59bf8be56043920ab293c99e888",
"EndpointID": "36c6bc23c59d4a99d1c292397cc7d72ad2cbbb15646a8bdb19f713b29e75f318",
"Gateway": "192.168.70.1",
"IPAddress": "192.168.70.3",
"IPPrefixLen": 24,
"IPv6Gateway": "",
"MacAddress": "02:42:c0:a8:46:03",
"DriverOpts": null
