Docker-compose.yml issue
Description of your problem
docker-compose.yml provided in the Run Graylog in Docker does not work when used with docker-compose up.
ERROR: yaml.scanner.ScannerError: mapping values are not allowed here
in “./docker-compose.yml”, line 5, column 23
I copied the yml file provided in sample. please let me know how to resolve this
Description of steps you’ve taken to attempt to solve the issue
Environmental information
Operating system information
  • Ubuntu
Package versions
  • Graylog-4.2
  • MongoDB-4.2
  • Elasticsearch-7.10.2
It looks like there have been a LOT of spaces mistakenly added in the port from our old docs site to the new docs site. You can try this version:
version: '3'
services:
  mongo:
    image: mongo:4
    container_name: mongodb
    networks:
      - graylog
    ports:
      - 27017:27017
  # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/6.x/docker.html
  elasticsearch:
    image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
    container_name: elasticsearch
    environment:
      - http.host=0.0.0.0
      - transport.host=localhost
      - network.host=0.0.0.0
      - "ES_JAVA_OPTS=-Xms1g -Xmx1g"
    ulimits:
      memlock:
        soft: -1
        hard: -1
    ports:
      - 9200:9200
    networks:
      - graylog
  graylog:
    image: graylog/graylog:4.2
    container_name: graylog
    environment:
      - GRAYLOG_PASSWORD_SECRET=<YOURSECRET>
      - GRAYLOG_ROOT_PASSWORD_SHA2=<YOURSHA2>
      - GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
      - GRAYLOG_ELASTICSEARCH_VERSION=7
      - GRAYLOG_HTTP_ENABLE_CORS=true
    networks:
      - graylog
    depends_on:
      - mongo
      - elasticsearch
    ports:
      - 9000:9000
      # Syslog TCP
      - 1514:1514
      # Syslog UDP
      - 1514:1514/udp
      # GELF TCP
      - 12201:12201
      # GELF UDP
      - 12201:12201/udp
      # Prometheus
      - 9091:9091
networks:
  graylog:
    driver: bridge
I’ve raised this with our technical writing team to have them address it.
thanks a ton for the timely help. It worked.
can you also please let me know where to find the graylog conf file? it is not present in /etc/
infact there is no graylog dir…but graylog is up and running
