Hi!
I am using Graylog 5.0 with Elasticsearch 7.10
Now, I want to move to Opensearch, but I did not find any manual on how to do that. All your docs are upgrading from Elasticsearch 7.10 to Opensearch 1.3
The only thing, I have found is:
https://go2docs.graylog.org/5-0/planning_your_deployment/opensearch_on_debian__tarball_.htm
… which is downloading Opensearch 1.3, although it should be 2.
Did anybody do that direct update with success and can tell me the “steps”?
Thank you and best wishes
KPS
