Debugging pipeline rules
hi,
where can I find the errors in the pipeline rules? The pipeline page tells me that there are quite a lot of errors, but I cannot see them in the server logs. I would like to see what causes the problems.
Where and what do you see exactly?
In /var/logs/graylog/server/current I see the following:
2017-06-16 19:08:13,225 WARN : org.graylog2.shared.events.DeadEventLoggingListener - Received unhandled event of type <org.graylog.plugins.pipelineprocessor.processors.PipelineInterpreter.State> from event bus <AsyncEventBus{graylog-eventbus}>
I assume this is a problem with the pipeline rule I just added?
rule "parse ACCESS log timestamp"
    has_field("event_ts")
    set_field("timestamp", $message.event_ts);
So how can I debug this rule further? The error above is pretty cryptic.
I saw these, too. And on the pipeline page there was info like 2 msg/s errors 2 msg/sec. (I have no access to the graylog right now).
