Here is a log split into a few replies:
administrator@INDOT-DN01:~$ tail -f /var/log/graylog-datanode/datanode.log
2026-04-22T09:44:42.462-04:00 WARN [OpensearchNodeHeartbeat] Opensearch REST api of process 3434 unavailable. Cause: Connection refused
2026-04-22T09:44:52.462-04:00 WARN [OpensearchNodeHeartbeat] Opensearch REST api of process 3434 unavailable. Cause: Connection refused
2026-04-22T09:45:02.462-04:00 WARN [OpensearchNodeHeartbeat] Opensearch REST api of process 3434 unavailable. Cause: Connection refused
2026-04-22T09:45:03.878-04:00 INFO [Server] SIGNAL received. Shutting down.
2026-04-22T09:45:03.879-04:00 INFO [GracefulShutdown] Graceful shutdown initiated.
2026-04-22T09:45:03.881-04:00 INFO [Periodicals] Shutting down periodical [org.graylog.datanode.bootstrap.preflight.DataNodeConfigurationPeriodical].
2026-04-22T09:45:03.881-04:00 INFO [Periodicals] Shutting down periodical [org.graylog2.events.ClusterEventPeriodical].
2026-04-22T09:45:03.881-04:00 INFO [GracefulShutdown] Goodbye.
2026-04-22T09:45:03.882-04:00 INFO [ClusterNodeStateTracer] Updating cluster node 65e90c32-e9b6-4128-afe0-5e67dbf36fc2 from UNAVAILABLE to UNAVAILABLE (reason: PROCESS_STOPPED)
2026-04-22T09:45:11.815-04:00 INFO [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2026-04-22T09:45:12.413-04:00 INFO [CmdLineTool] Running with JVM arguments: -Dlog4j.configurationFile=file:///etc/graylog/datanode/log4j2.xml -Xms1g -Xmx1g -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow -XX:+UnlockExperimentalVMOptions -Djdk.tls.acknowledgeCloseNotify=true
2026-04-22T09:45:12.624-04:00 INFO [cluster] Adding discovered server indot-mongo01:27017 to client view of cluster
2026-04-22T09:45:12.680-04:00 INFO [cluster] Adding discovered server indot-mongo02:27017 to client view of cluster
2026-04-22T09:45:12.713-04:00 INFO [cluster] Adding discovered server indot-mongo03:27017 to client view of cluster
2026-04-22T09:45:12.804-04:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=indot-mongo01:27017, type=REPLICA_SET_PRIMARY, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=25, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=71883624, setName=‘rs0’, canonicalAddress=INDOT-MONGO01:27017, hosts=[INDOT-MONGO03:27017, INDOT-MONGO01:27017, INDOT-MONGO02:27017], passives=, arbiters=, primary=‘INDOT-MONGO01:27017’, tagSet=TagSet{}, electionId=7fffffff0000000000000003, setVersion=85770, topologyVersion=TopologyVersion{processId=69e0eb3fa687e6d5a997bf6d, counter=5}, lastWriteDate=Wed Apr 22 09:45:12 EDT 2026, lastUpdateTimeNanos=518866016112419}
2026-04-22T09:45:12.806-04:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=indot-mongo03:27017, type=REPLICA_SET_SECONDARY, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=25, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=32738672, setName=‘rs0’, canonicalAddress=INDOT-MONGO03:27017, hosts=[INDOT-MONGO03:27017, INDOT-MONGO01:27017, INDOT-MONGO02:27017], passives=, arbiters=, primary=‘INDOT-MONGO01:27017’, tagSet=TagSet{}, electionId=null, setVersion=85770, topologyVersion=TopologyVersion{processId=69e0ec308644def10abfbe59, counter=3}, lastWriteDate=Wed Apr 22 09:45:12 EDT 2026, lastUpdateTimeNanos=518866009126735}
2026-04-22T09:45:12.809-04:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=indot-mongo02:27017, type=REPLICA_SET_SECONDARY, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=25, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=41811066, setName=‘rs0’, canonicalAddress=INDOT-MONGO02:27017, hosts=[INDOT-MONGO03:27017, INDOT-MONGO01:27017, INDOT-MONGO02:27017], passives=, arbiters=, primary=‘INDOT-MONGO01:27017’, tagSet=TagSet{}, electionId=null, setVersion=85770, topologyVersion=TopologyVersion{processId=69e0eb8d99e0da191c59c1da, counter=3}, lastWriteDate=Wed Apr 22 09:45:12 EDT 2026, lastUpdateTimeNanos=518866005909624}
2026-04-22T09:45:12.819-04:00 INFO [cluster] Discovered replica set primary indot-mongo01:27017 with max election id 7fffffff0000000000000003 and max set version 85770
2026-04-22T09:45:12.839-04:00 INFO [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver|legacy”, “version”: “5.0.0”}, “os”: {“type”: “Linux”, “name”: “Linux”, “architecture”: “amd64”, “version”: “6.17.0-14-generic”}, “platform”: “Java/Eclipse Adoptium/17.0.14+7”} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=, codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@4c18621b, com.mongodb.Jep395RecordCodecProvider@39c385d6, com.mongodb.KotlinCodecProvider@1cec219f]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[indot-mongo01:27017, indot-mongo02:27017, indot-mongo03:27017], srvServiceName=mongodb, mode=MULTIPLE, requiredClusterType=REPLICA_SET, requiredReplicaSetName=‘rs0’, serverSelector=‘null’, clusterListeners=‘’, serverSelectionTimeout=‘30000 ms’, localThreshold=‘15 ms’}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=, maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners=‘’, serverMonitorListeners=‘’}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName=‘null’, compressorList=, uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null}
2026-04-22T09:45:12.844-04:00 INFO [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver”, “version”: “5.0.0”}, “os”: {“type”: “Linux”, “name”: “Linux”, “architecture”: “amd64”, “version”: “6.17.0-14-generic”}, “platform”: “Java/Eclipse Adoptium/17.0.14+7”} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=, codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@4c18621b, com.mongodb.Jep395RecordCodecProvider@39c385d6, com.mongodb.KotlinCodecProvider@1cec219f]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[indot-mongo01:27017, indot-mongo02:27017, indot-mongo03:27017], srvServiceName=mongodb, mode=MULTIPLE, requiredClusterType=REPLICA_SET, requiredReplicaSetName=‘rs0’, serverSelector=‘null’, clusterListeners=‘’, serverSelectionTimeout=‘30000 ms’, localThreshold=‘15 ms’}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=, maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners=‘’, serverMonitorListeners=‘’}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName=‘null’, compressorList=, uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null}
2026-04-22T09:45:12.997-04:00 INFO [MongoDBPreflightCheck] Connected to MongoDB version 8.0.19
2026-04-22T09:45:13.125-04:00 INFO [DatanodeDirectories] Opensearch of the node 65e90c32-e9b6-4128-afe0-5e67dbf36fc2 uses following directories as its storage: DatanodeDirectories{dataTargetDir=‘/var/lib/graylog-datanode/opensearch/data’, logsTargetDir=‘/var/log/graylog-datanode/opensearch’, configurationSourceDir=‘Optional[/etc/graylog/datanode]’, configurationTargetDir=‘/var/lib/graylog-datanode/opensearch/config’, opensearchProcessConfigurationDir=‘/var/lib/graylog-datanode/opensearch/config/opensearch’}
2026-04-22T09:45:13.230-04:00 INFO [OpensearchConfigSync] Directory used for Opensearch process configuration is /var/lib/graylog-datanode/opensearch/config/opensearch
2026-04-22T09:45:13.273-04:00 INFO [OpensearchConfigSync] Synchronizing Opensearch configuration
2026-04-22T09:45:13.281-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/datanode-truststore.p12
2026-04-22T09:45:13.282-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/jvm.options
2026-04-22T09:45:13.283-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/log4j2.properties
2026-04-22T09:45:13.284-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch.yml
2026-04-22T09:45:13.285-04:00 INFO [FullDirSync] Deleting obsolete directory /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security
2026-04-22T09:45:13.313-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/config.yml
2026-04-22T09:45:13.316-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/tenants.yml
2026-04-22T09:45:13.316-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/roles.yml
2026-04-22T09:45:13.318-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/roles_mapping.yml
2026-04-22T09:45:13.321-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/audit.yml
2026-04-22T09:45:13.321-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/action_groups.yml
2026-04-22T09:45:13.321-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/whitelist.yml
2026-04-22T09:45:13.322-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/nodes_dn.yml
2026-04-22T09:45:13.324-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/opensearch.yml.example
2026-04-22T09:45:13.324-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/internal_users.yml
2026-04-22T09:45:13.325-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/allowlist.yml
2026-04-22T09:45:13.328-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/transport-keystore.p12
2026-04-22T09:45:13.328-04:00 INFO [FullDirSync] Deleting obsolete directory /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-observability
2026-04-22T09:45:13.330-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-observability/observability.yml
2026-04-22T09:45:13.330-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch.keystore
2026-04-22T09:45:13.330-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/http-keystore.p12
2026-04-22T09:45:13.332-04:00 INFO [FullDirSync] Deleting obsolete file /var/lib/graylog-datanode/opensearch/config/opensearch/unicast_hosts.txt
2026-04-22T09:45:13.340-04:00 INFO [FullDirSync] Synchronizing directory /var/lib/graylog-datanode/opensearch/config/opensearch
2026-04-22T09:45:13.343-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/log4j2.properties
2026-04-22T09:45:13.345-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/jvm.options
2026-04-22T09:45:13.348-04:00 INFO [FullDirSync] Synchronizing directory /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-observability
2026-04-22T09:45:13.349-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-observability/observability.yml
2026-04-22T09:45:13.352-04:00 INFO [FullDirSync] Synchronizing directory /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security
2026-04-22T09:45:13.357-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/whitelist.yml
2026-04-22T09:45:13.359-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/opensearch.yml.example
2026-04-22T09:45:13.360-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/allowlist.yml
2026-04-22T09:45:13.362-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/roles_mapping.yml
2026-04-22T09:45:13.367-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/internal_users.yml
2026-04-22T09:45:13.368-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/action_groups.yml
2026-04-22T09:45:13.369-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/audit.yml
2026-04-22T09:45:13.371-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/config.yml
2026-04-22T09:45:13.372-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/tenants.yml
2026-04-22T09:45:13.374-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/nodes_dn.yml
2026-04-22T09:45:13.375-04:00 INFO [FullDirSync] Synchronizing file /var/lib/graylog-datanode/opensearch/config/opensearch/opensearch-security/roles.yml
2026-04-22T09:45:13.380-04:00 INFO [OpensearchDistributionProvider] Found following opensearch distributions: [/usr/share/graylog-datanode/dist/opensearch-2.12.0-linux-x64]
2026-04-22T09:45:13.752-04:00 INFO [DatanodeDirectories] Opensearch of the node 65e90c32-e9b6-4128-afe0-5e67dbf36fc2 uses following directories as its storage: DatanodeDirectories{dataTargetDir=‘/var/lib/graylog-datanode/opensearch/data’, logsTargetDir=‘/var/log/graylog-datanode/opensearch’, configurationSourceDir=‘Optional[/etc/graylog/datanode]’, configurationTargetDir=‘/var/lib/graylog-datanode/opensearch/config’, opensearchProcessConfigurationDir=‘/var/lib/graylog-datanode/opensearch/config/opensearch’}
2026-04-22T09:45:13.884-04:00 INFO [cluster] Adding discovered server indot-mongo01:27017 to client view of cluster
2026-04-22T09:45:13.894-04:00 INFO [cluster] Adding discovered server indot-mongo02:27017 to client view of cluster
2026-04-22T09:45:13.902-04:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=indot-mongo01:27017, type=REPLICA_SET_PRIMARY, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=25, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=3300606, setName=‘rs0’, canonicalAddress=INDOT-MONGO01:27017, hosts=[INDOT-MONGO03:27017, INDOT-MONGO01:27017, INDOT-MONGO02:27017], passives=, arbiters=, primary=‘INDOT-MONGO01:27017’, tagSet=TagSet{}, electionId=7fffffff0000000000000003, setVersion=85770, topologyVersion=TopologyVersion{processId=69e0eb3fa687e6d5a997bf6d, counter=5}, lastWriteDate=Wed Apr 22 09:45:13 EDT 2026, lastUpdateTimeNanos=518867117827287}
2026-04-22T09:45:13.905-04:00 INFO [cluster] Adding discovered server indot-mongo03:27017 to client view of cluster
2026-04-22T09:45:13.910-04:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=indot-mongo02:27017, type=REPLICA_SET_SECONDARY, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=25, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=2336958, setName=‘rs0’, canonicalAddress=INDOT-MONGO02:27017, hosts=[INDOT-MONGO03:27017, INDOT-MONGO01:27017, INDOT-MONGO02:27017], passives=, arbiters=, primary=‘INDOT-MONGO01:27017’, tagSet=TagSet{}, electionId=null, setVersion=85770, topologyVersion=TopologyVersion{processId=69e0eb8d99e0da191c59c1da, counter=3}, lastWriteDate=Wed Apr 22 09:45:13 EDT 2026, lastUpdateTimeNanos=518867129217363}
2026-04-22T09:45:13.916-04:00 INFO [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver|legacy”, “version”: “5.0.0”}, “os”: {“type”: “Linux”, “name”: “Linux”, “architecture”: “amd64”, “version”: “6.17.0-14-generic”}, “platform”: “Java/Eclipse Adoptium/17.0.14+7”} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=, codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@4c18621b, com.mongodb.Jep395RecordCodecProvider@39c385d6, com.mongodb.KotlinCodecProvider@1cec219f]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[indot-mongo01:27017, indot-mongo02:27017, indot-mongo03:27017], srvServiceName=mongodb, mode=MULTIPLE, requiredClusterType=REPLICA_SET, requiredReplicaSetName=‘rs0’, serverSelector=‘null’, clusterListeners=‘’, serverSelectionTimeout=‘30000 ms’, localThreshold=‘15 ms’}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=, maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners=‘’, serverMonitorListeners=‘’}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName=‘null’, compressorList=, uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null}
2026-04-22T09:45:13.921-04:00 INFO [cluster] Discovered replica set primary indot-mongo01:27017 with max election id 7fffffff0000000000000003 and max set version 85770
2026-04-22T09:45:13.924-04:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=indot-mongo03:27017, type=REPLICA_SET_SECONDARY, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=25, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=3634044, setName=‘rs0’, canonicalAddress=INDOT-MONGO03:27017, hosts=[INDOT-MONGO03:27017, INDOT-MONGO01:27017, INDOT-MONGO02:27017], passives=, arbiters=, primary=‘INDOT-MONGO01:27017’, tagSet=TagSet{}, electionId=null, setVersion=85770, topologyVersion=TopologyVersion{processId=69e0ec308644def10abfbe59, counter=3}, lastWriteDate=Wed Apr 22 09:45:13 EDT 2026, lastUpdateTimeNanos=518867143654517}
2026-04-22T09:45:13.930-04:00 INFO [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver”, “version”: “5.0.0”}, “os”: {“type”: “Linux”, “name”: “Linux”, “architecture”: “amd64”, “version”: “6.17.0-14-generic”}, “platform”: “Java/Eclipse Adoptium/17.0.14+7”} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=, codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@4c18621b, com.mongodb.Jep395RecordCodecProvider@39c385d6, com.mongodb.KotlinCodecProvider@1cec219f]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[indot-mongo01:27017, indot-mongo02:27017, indot-mongo03:27017], srvServiceName=mongodb, mode=MULTIPLE, requiredClusterType=REPLICA_SET, requiredReplicaSetName=‘rs0’, serverSelector=‘null’, clusterListeners=‘’, serverSelectionTimeout=‘30000 ms’, localThreshold=‘15 ms’}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=, maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners=‘’, serverMonitorListeners=‘’}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName=‘null’, compressorList=, uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null}
2026-04-22T09:45:16.377-04:00 INFO [DbEntitiesScanner] 14 entities have been scanned and added to DB Entity Catalog, it took 1.791 s
2026-04-22T09:45:16.443-04:00 INFO [ServerBootstrap] Graylog datanode 6.0.14+508aa86 starting up
2026-04-22T09:45:16.448-04:00 INFO [ServerBootstrap] JRE: Eclipse Adoptium 17.0.14 on Linux 6.17.0-14-generic
2026-04-22T09:45:16.452-04:00 INFO [ServerBootstrap] Deployment: deb
2026-04-22T09:45:16.455-04:00 INFO [ServerBootstrap] OS: Ubuntu 24.04.4 LTS (noble)
2026-04-22T09:45:16.455-04:00 INFO [ServerBootstrap] Arch: amd64
2026-04-22T09:45:16.569-04:00 INFO [PeriodicalsService] Starting 6 periodicals …
2026-04-22T09:45:16.570-04:00 INFO [PeriodicalsService] Delaying start of 1 periodicals until this node becomes leader …
2026-04-22T09:45:16.571-04:00 INFO [Periodicals] Starting [org.graylog.datanode.periodicals.ClusterManagerDiscovery] periodical in [0s], polling every [10s].
2026-04-22T09:45:16.604-04:00 INFO [Periodicals] Starting [org.graylog.datanode.periodicals.NodePingPeriodical] periodical in [0s], polling every [1s].
2026-04-22T09:45:16.609-04:00 INFO [Periodicals] Starting [org.graylog.datanode.periodicals.MetricsCollector] periodical in [0s], polling every [60s].
2026-04-22T09:45:16.610-04:00 INFO [Periodicals] Starting [org.graylog.datanode.periodicals.OpensearchNodeHeartbeat] periodical in [0s], polling every [10s].
2026-04-22T09:45:16.613-04:00 INFO [Periodicals] Starting [org.graylog.datanode.bootstrap.preflight.DataNodeConfigurationPeriodical] periodical in [0s], polling every [2s].
2026-04-22T09:45:16.616-04:00 INFO [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2026-04-22T09:45:16.813-04:00 INFO [OpensearchSecurityConfiguration] Opensearch transport certificate has following alternative names: 127.0.0.1, 0:0:0:0:0:0:0:1, localhost, INDOT-DN01, ip6-localhost, 10.10.40.7
2026-04-22T09:45:16.828-04:00 INFO [OpensearchSecurityConfiguration] Opensearch HTTP certificate has following alternative names: 127.0.0.1, 0:0:0:0:0:0:0:1, localhost, INDOT-DN01, ip6-localhost, 10.10.40.7
2026-04-22T09:45:16.862-04:00 INFO [TruststoreCreator] Adding certificate transport-chain-CA-root to the truststore
2026-04-22T09:45:16.863-04:00 INFO [TruststoreCreator] Adding certificate http-chain-CA-root to the truststore
2026-04-22T09:45:16.994-04:00 INFO [OpensearchDistributionProvider] Found following opensearch distributions: [/usr/share/graylog-datanode/dist/opensearch-2.12.0-linux-x64]
2026-04-22T09:45:17.100-04:00 INFO [OpensearchSecurityConfiguration] Opensearch transport certificate has following alternative names: 127.0.0.1, 0:0:0:0:0:0:0:1, localhost, INDOT-DN01, ip6-localhost, 10.10.40.7
2026-04-22T09:45:17.111-04:00 INFO [OpensearchSecurityConfiguration] Opensearch HTTP certificate has following alternative names: 127.0.0.1, 0:0:0:0:0:0:0:1, localhost, INDOT-DN01, ip6-localhost, 10.10.40.7
2026-04-22T09:45:17.140-04:00 INFO [TruststoreCreator] Adding certificate transport-chain-CA-root to the truststore
2026-04-22T09:45:17.141-04:00 INFO [TruststoreCreator] Adding certificate http-chain-CA-root to the truststore
2026-04-22T09:45:17.244-04:00 INFO [OpensearchCommandLineProcess] No S3 repository configuration provided, skipping plugin initialization
2026-04-22T09:45:17.516-04:00 INFO [CommandLineProcess] Running process from /usr/share/graylog-datanode/dist/opensearch-2.12.0-linux-x64/bin/opensearch
2026-04-22T09:45:17.529-04:00 INFO [JerseyService] Starting Data node REST API
2026-04-22T09:45:17.534-04:00 INFO [ClusterNodeStateTracer] Updating cluster node 65e90c32-e9b6-4128-afe0-5e67dbf36fc2 from UNCONFIGURED to STARTING (reason: PROCESS_STARTED)
2026-04-22T09:45:17.584-04:00 INFO [ServerBootstrap] Services started, startup times in ms: {GracefulShutdownService [RUNNING]=0, PeriodicalsService [RUNNING]=56, OpensearchProcessService [RUNNING]=1016}
2026-04-22T09:45:17.585-04:00 INFO [ServerBootstrap] Graylog DataNode datanode up and running.
2026-04-22T09:45:18.545-04:00 INFO [Version] HV000001: Hibernate Validator 8.0.1.Final
2026-04-22T09:45:19.107-04:00 INFO [NetworkListener] Started listener bound to [10.10.40.7:8999]
2026-04-22T09:45:19.111-04:00 INFO [HttpServer] [HttpServer] Started.
2026-04-22T09:45:19.112-04:00 INFO [JerseyService] Started REST API at <10.10.40.7:8999>
2026-04-22T09:45:20.720-04:00 WARN [OpensearchProcessImpl] WARNING: A terminally deprecated method in java.lang.System has been called
2026-04-22T09:45:20.723-04:00 WARN [OpensearchProcessImpl] WARNING: System::setSecurityManager has been called by org.opensearch.bootstrap.OpenSearch (file:/usr/share/graylog-datanode/dist/opensearch-2.12.0-linux-x64/lib/opensearch-2.12.0.jar)
2026-04-22T09:45:20.726-04:00 WARN [OpensearchProcessImpl] WARNING: Please consider reporting this to the maintainers of org.opensearch.bootstrap.OpenSearch
2026-04-22T09:45:20.729-04:00 WARN [OpensearchProcessImpl] WARNING: System::setSecurityManager will be removed in a future release
2026-04-22T09:45:21.742-04:00 WARN [OpensearchProcessImpl] Apr 22, 2026 9:45:21 AM sun.util.locale.provider.LocaleProviderAdapter
2026-04-22T09:45:21.744-04:00 WARN [OpensearchProcessImpl] WARNING: COMPAT locale provider will be removed in a future release
2026-04-22T09:45:22.342-04:00 WARN [OpensearchProcessImpl] WARNING: A terminally deprecated method in java.lang.System has been called
2026-04-22T09:45:22.345-04:00 WARN [OpensearchProcessImpl] WARNING: System::setSecurityManager has been called by org.opensearch.bootstrap.Security (file:/usr/share/graylog-datanode/dist/opensearch-2.12.0-linux-x64/lib/opensearch-2.12.0.jar)
2026-04-22T09:45:22.345-04:00 WARN [OpensearchProcessImpl] WARNING: Please consider reporting this to the maintainers of org.opensearch.bootstrap.Security
2026-04-22T09:45:22.345-04:00 WARN [OpensearchProcessImpl] WARNING: System::setSecurityManager will be removed in a future release
2026-04-22T09:45:22.374-04:00 INFO [OpensearchProcessImpl] [2026-04-22T09:45:22,370][INFO ][o.o.n.Node ] [INDOT-DN01] version[2.12.0], pid[38424], build[tar/2c355ce1a427e4a528778d4054436b5c4b756221/2024-02-20T02:18:49.874618333Z], OS[Linux/6.17.0-14-generic/amd64], JVM[Eclipse Adoptium/OpenJDK 64-Bit Server VM/21.0.2/21.0.2+13-LTS]
2026-04-22T09:45:22.378-04:00 INFO [OpensearchProcessImpl] [2026-04-22T09:45:22,377][INFO ][o.o.n.Node ] [INDOT-DN01] JVM home [/usr/share/graylog-datanode/dist/opensearch-2.12.0-linux-x64/jdk], using bundled JDK/JRE [true]
2026-04-22T09:45:22.379-04:00 INFO [OpensearchProcessImpl] [2026-04-22T09:45:22,377][INFO ][o.o.n.Node ] [INDOT-DN01] JVM arguments [-Xshar
