Datanode/Opensearch Issue After Upgrade to graylog-enterprise 7.0
I’m using graylog security on a Ubuntu 22 VM and until the latest version 6.3.5 everything was working smoothly.
When I initially wanted to upgrade graylog-server to 7.0.1 then graylog-datanode to 7.0.1 the CPU spikes to 100% (no mater how much CPU I’m assinging to the instance).
I revert the upgrade and try to only upgrade graylog-server to 7.0.1 and let graylog-datanode to 6.3.5 and it went better … for approx. 24h, then the CPU spikes to 100% again
  • OS Information: Ubuntu 22.04 LTS
  • Package Version:
    graylog-datanode: 6.3.5-1
    graylog-enterprise 7.0.1-1
    mongodb-org-server 8.0.15
    Opensearch (as per the folder name): 2.15.0
    datanode.log is full of line like :
[OpensearchProcessImpl] [2025-11-28T15:34:15,865][WARN ][o.o.s.b.SearchBackpressureService] [SERVER] [monitor_only mode] cancelling task [5418249] due to high resource consumption [elapsed time exceeded [30.8s >= 30s]]
I tried to avoid updating to datanode 7.0.1 but the issue raise again after 24h
Hello @Nono,
This is difficult to diagnose without a holistic view of the cluster. Could you share the full data node log?
It turns out that our illuminate Sigma rules had too much to handle after the update so it DDoS itself by timing out and re-applying the rules/search.
After waiting 24/48h, the last upgrade went fine.
Thanks for the update @Nono.
While it’s great you are happy to rely on the community for answers, as an enterprise user you can also contact Graylog support for help should you require it.
