Graylog Datanode Issue After Upgrade to 7.0
1. Describe your incident: I have been running Graylog 6.3 in docker fine for a while now, and most recently I upgraded to 7.0, including the data-node. Everything went just fine, from what I could tell, but all of a sudden, I’ve noticed that the data-node won’t start now.
  • OS Information: Ubuntu 24.04.3 // Docker version 29.0.1, build eedd969
  • Package Version: 7.0.0, I think.
2025-11-17T15:30:59.887Z INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2025-11-17T15:30:59.939Z WARN  [PluginLoader] Plugin directory /plugin does not exist, not loading plugins.
2025-11-17T15:31:00.335Z INFO  [CmdLineTool] Running with JVM arguments: -Dlog4j.configurationFile=file:///etc/graylog/datanode/log4j2.xml -Xms1g -Xmx1g -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow -XX:+UnlockExperimentalVMOptions -Djdk.tls.acknowledgeCloseNotify=true
2025-11-17T15:31:00.790Z INFO  [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "5.6.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.8.0-87-generic"}, "platform": "Java/Eclipse Adoptium/21.0.8+9-LTS", "env": {"container": {"runtime": "docker"}}} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@2ffb3aec, com.mongodb.Jep395RecordCodecProvider@786ff1cb, com.mongodb.KotlinCodecProvider@46039a21, EnumCodecProvider{}]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[mongodb:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2025-11-17T15:31:00.792Z INFO  [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "5.6.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.8.0-87-generic"}, "platform": "Java/Eclipse Adoptium/21.0.8+9-LTS", "env": {"container": {"runtime": "docker"}}} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@2ffb3aec, com.mongodb.Jep395RecordCodecProvider@786ff1cb, com.mongodb.KotlinCodecProvider@46039a21, EnumCodecProvider{}]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[mongodb:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2025-11-17T15:31:00.824Z INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=mongodb:27017, type=STANDALONE, cryptd=false, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=21, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=20973875, minRoundTripTimeNanos=0}
2025-11-17T15:31:00.826Z INFO  [cluster] Waiting for server to become available for operation { ping: 1 } with ID 3. Remaining time: 29993 ms. Selector: ReadPreferenceServerSelector{readPreference=primary}, topology description: {type=UNKNOWN, servers=[{address=mongodb:27017, type=UNKNOWN, state=CONNECTING}].
2025-11-17T15:31:00.890Z INFO  [DatanodeDirectories] Opensearch of the node 78dafb63-9a67-417b-9cf9-89664eee18af uses following directories as its storage: DatanodeDirectories{dataTargetDir='/var/lib/graylog-datanode/opensearch/data', logsTargetDir='/var/lib/graylog-datanode/opensearch/logs', configurationSourceDir='Optional.empty', configurationTargetDir='/var/lib/graylog-datanode/opensearch/config'}
2025-11-17T15:31:00.932Z INFO  [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "5.6.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.8.0-87-generic"}, "platform": "Java/Eclipse Adoptium/21.0.8+9-LTS", "env": {"container": {"runtime": "docker"}}} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@2ffb3aec, com.mongodb.Jep395RecordCodecProvider@786ff1cb, com.mongodb.KotlinCodecProvider@46039a21, EnumCodecProvider{}]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[mongodb:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2025-11-17T15:31:00.933Z INFO  [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "5.6.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.8.0-87-generic"}, "platform": "Java/Eclipse Adoptium/21.0.8+9-LTS", "env": {"container": {"runtime": "docker"}}} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@2ffb3aec, com.mongodb.Jep395RecordCodecProvider@786ff1cb, com.mongodb.KotlinCodecProvider@46039a21, EnumCodecProvider{}]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[mongodb:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2025-11-17T15:31:00.934Z INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=mongodb:27017, type=STANDALONE, cryptd=false, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=21, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=1143058, minRoundTripTimeNanos=0}
2025-11-17T15:31:00.934Z INFO  [cluster] Waiting for server to become available for operation { ping: 1 } with ID 10. Remaining time: 29999 ms. Selector: ReadPreferenceServerSelector{readPreference=primary}, topology description: {type=UNKNOWN, servers=[{address=mongodb:27017, type=UNKNOWN, state=CONNECTING}].
2025-11-17T15:31:00.965Z INFO  [MongoDBPreflightCheck] Connected to MongoDB version 7.0.25
WARNING: A restricted method in java.lang.foreign.Linker has been called
WARNING: java.lang.foreign.Linker::downcallHandle has been called by the unnamed module
WARNING: Use --enable-native-access=ALL-UNNAMED to avoid a warning for this module
2025-11-17T15:31:01.071Z INFO  [MemorySegmentIndexInputProvider] Using MemorySegmentIndexInput and native madvise support with Java 21 or later; to disable start with -Dorg.apache.lucene.store.MMapDirectory.enableMemorySegments=false
2025-11-17T15:31:01.145Z ERROR [CmdLineTool] Startup error:
org.graylog.datanode.filesystem.index.IndexerInformationParserException: No state file available in dir  /var/lib/graylog-datanode/opensearch/data/nodes/0/indices/iGKTdCeuTuSPEFclJq11fw
	at org.graylog.datanode.filesystem.index.IndicesDirectoryParser.lambda$findStateFile$9(IndicesDirectoryParser.java:136)
	at java.base/java.util.Optional.orElseThrow(Unknown Source)
	at org.graylog.datanode.filesystem.index.IndicesDirectoryParser.findStateFile(IndicesDirectoryParser.java:136)
	at org.graylog.datanode.filesystem.index.IndicesDirectoryParser.getState(IndicesDirectoryParser.java:102)
	at org.graylog.datanode.filesystem.index.IndicesDirectoryParser.parseIndex(IndicesDirectoryParser.java:108)
	at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
	at java.base/java.util.Iterator.forEachRemaining(Unknown Source)
	at java.base/java.util.Spliterators$IteratorSpliterator.forEachRemaining(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
	at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
	at java.base/java.util.stream.ReferencePipeline.collect(Unknown Source)
	at org.graylog.datanode.filesystem.index.IndicesDirectoryParser.parseNode(IndicesDirectoryParser.java:94)
	at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.evaluateToArrayNode(Unknown Source)
	at java.base/java.util.stream.ReferencePipeline.toArray(Unknown Source)
	at java.base/java.util.stream.ReferencePipeline.toList(Unknown Source)
	at org.graylog.datanode.filesystem.index.IndicesDirectoryParser.parse(IndicesDirectoryParser.java:77)
	at org.graylog.datanode.bootstrap.preflight.OpensearchDataDirCompatibilityCheck.runCheck(OpensearchDataDirCompatibilityCheck.java:59)
	at com.google.common.collect.ImmutableList.forEach(ImmutableList.java:421)
	at org.graylog2.bootstrap.preflight.PreflightCheckService.runChecks(PreflightCheckService.java:52)
	at org.graylog.datanode.bootstrap.DatanodeBootstrap.runPreFlightChecks(DatanodeBootstrap.java:81)
	at org.graylog.datanode.bootstrap.DatanodeBootstrap.beforeInjectorCreation(DatanodeBootstrap.java:76)
	at org.graylog2.bootstrap.CmdLineTool.doRun(CmdLineTool.java:362)
	at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:287)
	at org.graylog.datanode.bootstrap.Main.main(Main.java:59)
Exception in thread "main" org.graylog.datanode.filesystem.index.IndexerInformationParserException: No state file available in dir  /var/lib/graylog-datanode/opensearch/data/nodes/0/indices/iGKTdCeuTuSPEFclJq11fw
3. What steps have you already taken to try and solve the problem? I’m not even sure where to begin. It was working just fine, and now it’s not. I don’t think I changed anything (although the Docker version did get upgraded)/
4. How can the community help? Does anyone have an idea what I could even start to do to troubleshoot with what’s going on?
Hi @JSylvia007,
This seems like a broken index dir / file. But there is good chance that only the preflight check is failing and opensearch in datanode is able to restore the state without problems. So I’d suggest setting skip_preflight_checks=true in your datanode.conf, or GRAYLOG_DATANODE_SKIP_PREFLIGHT_CHECKS=true in your env. This will skip the problematic check and let opensearch start.
Please let me know if that helped and your opensearch in datanode can start.
That worked!!! How can I fix whatever is wrong with the preflight check? I assume that I don’t want to skip it forever. Or was this simple a start enough to get things back where they need to be?
Try to set skip_preflight_checks=false and restart your datanode. I guess the opensearch now fixed your index files and the preflight check could work just fine.
If not, please let me know and we’ll investigate further. You are right that it’s safer to have the preflight checks enabled and no skipping them forever.
Thanks!
So… I set it to “false”, and it went back to the same issue with the same directory… Maybe something is broken about that index? I set it back to “true”, and the container and Graylog started right up.
Yeah, it’s probably something slightly wrong with the index itself. Opensearch can ignore the problem and start fine, but graylog preflight logic is too strict. Depending on your setup, rotation and retention, maybe the problem will solve itself sooner or later.
I created an issue to track the progress, if you are interested: IndexerInformationParserException: No state file available in dir · Issue #24358 · Graylog2/graylog2-server · GitHub
Meanwhile, I’d recommend keeping the preflight checks disabled.
Thanks!
I appreciate it. I will keep following this and the Github Issue hoping that it gets some traction. Hopefully there’s some command line that can fix it.
