"Data Node Heap Size Warning" when running Graylog in Docker
I’ve installed a Graylog with docker-compose and set the environment variable “GRAYLOG_DATANODE_OPENSEARCH_HEAP” to increase Java heap size, but the alert still ocurring
My setup:
  • Debian 12
  • Docker version 20.10.24+dfsg1, build 297e128
  • Docker compose file
# For DataNode setup, graylog starts with a preflight UI, this is a change from just using OpenSearch/Elasticsearch.
# Please take a look at the README at the top of this repo or the regular docs for more info.
services:
  mongodb:
    image: "mongo:7.0"
    restart: "unless-stopped"
    networks:
      - graylog
    volumes:
      - "mongodb_data:/data/db"
      - "mongodb_config:/data/configdb"
  # Graylog Data Node: https://hub.docker.com/r/graylog/graylog-datanode
  # ⚠️ Make sure this is set on the host before starting:
  # echo "vm.max_map_count=262144" | sudo tee -a /etc/sysctl.conf
  # sudo sysctl -p
  datanode:
    image: "${DATANODE_IMAGE:-graylog/graylog-datanode:7.0}"
    hostname: "datanode"
    environment:
      GRAYLOG_DATANODE_NODE_ID_FILE: "/var/lib/graylog-datanode/node-id"
      # GRAYLOG_DATANODE_PASSWORD_SECRET and GRAYLOG_PASSWORD_SECRET MUST be the same value
      GRAYLOG_DATANODE_PASSWORD_SECRET: "${GRAYLOG_PASSWORD_SECRET:?Please configure GRAYLOG_PASSWORD_SECRET in the .env file}"
      GRAYLOG_DATANODE_MONGODB_URI: "mongodb://mongodb:27017/graylog"
      GRAYLOG_DATANODE_OPENSEARCH_HEAP: "5g"
    ulimits:
      memlock:
        hard: -1
        soft: -1
      nofile:
        soft: 65536
        hard: 65536
    ports:
      - "127.0.0.1:8999:8999/tcp"   # DataNode API
      - "127.0.0.1:9200:9200/tcp"
      - "127.0.0.1:9300:9300/tcp"
    networks:
      - graylog
    volumes:
      - "graylog-datanode:/var/lib/graylog-datanode"
    restart: "on-failure"
  # Graylog: https://hub.docker.com/r/graylog/graylog-enterprise
  graylog:
    hostname: "server"
    image: "${GRAYLOG_IMAGE:-graylog/graylog:7.0}"
    depends_on:
      mongodb:
        condition: "service_started"
      datanode:
    entrypoint: "/usr/bin/tini --  /docker-entrypoint.sh"
    environment:
      GRAYLOG_NODE_ID_FILE: "/usr/share/graylog/data/data/node-id"
      GRAYLOG_PASSWORD_SECRET: "${GRAYLOG_PASSWORD_SECRET:?Please configure GRAYLOG_PASSWORD_SECRET in the .env file}"
      GRAYLOG_ROOT_PASSWORD_SHA2: "${GRAYLOG_ROOT_PASSWORD_SHA2:?Please configure GRAYLOG_ROOT_PASSWORD_SHA2 in the .env file}"
      GRAYLOG_HTTP_BIND_ADDRESS: "0.0.0.0:9000"
      GRAYLOG_HTTP_EXTERNAL_URI: "http://localhost:9000/"
      GRAYLOG_MONGODB_URI: "mongodb://mongodb:27017/graylog"
    ports:
    #- "0.0.0.0:5044:5044/tcp"   # Beats
    #- "127.0.0.1:5140:5140/udp"   # Syslog
    #- "127.0.0.1:5140:5140/tcp"   # Syslog
    #- "127.0.0.1:5555:5555/tcp"   # RAW TCP
    #- "127.0.0.1:5555:5555/udp"   # RAW UDP
    - "0.0.0.0:9000:9000/tcp"   # Server API
    #- "127.0.0.1:12201:12201/tcp" # GELF TCP
    #- "127.0.0.1:12201:12201/udp" # GELF UDP
    #- "127.0.0.1:10000:10000/tcp" # Custom TCP port
    #- "127.0.0.1:10000:10000/udp" # Custom UDP port
    #- "127.0.0.1:13301:13301/tcp" # Forwarder data
    #- "127.0.0.1:13302:13302/tcp" # Forwarder config
    - "0.0.0.0:30514:30514/udp"   # A10 log
    networks:
      - graylog
    volumes:
      - "graylog_data:/usr/share/graylog/data/data"
networks:
  graylog:
    driver: "bridge"
volumes:
  mongodb_data:
  mongodb_config:
  graylog-datanode:
  graylog_data:
If someone has any idea about it, I appreciate it!
Thanks!
Hi @nochexa,
Just to be extra sure, have you closed/removed the original notification and it’s still appearing? If yes, does the new one show the updated RAM size configuration?
Thanks!
